[GRASS5] Re: v.in.shp on solaris2.7,5.0.0pre3
John Gillette wrote:
David,
Here is a listing of what happens.
One other question. I am trying to compile your arctest1
program to be able to extract the shp files. Possibly
an interim solution until v.in..shape works.
But I get an undefined symbol G_fatal_error and G_warning.
I am using Sun's "make" and I assume that the problem is I am
not including something. Do you know where G_fatal_error and
G_warning reside, I mean as in what library or object file
these are in? (I know that v.in.shape compiles...)
They are declared in src/include/gisdefs.h. Defined in src/libes/gis/error.c and (I assume) included in libgis.a. But a standard setup should pick up these without any problems. Probably, the module should be built in the GRASS environment, as this will be needed to configure the various include and lib directories needed for any GRASS specific code.
gcc -g -L/usr/lib -lm -o arctest1 shpopen.o dbfopen.o shp2dig.o dbutils.o writelin.o gbtree.o arctest1.o
John
v.in.shape input=/scratch/grassdata/gishome/n784903L.shp verbose=9
logfile=ZZZlogfile label=TAG
Extracting all records.
Creating vector network...
    Processing shape 1 of 328.
    Processing shape 2 of 328.
    [... more of the same]
    Processing shape 328 of 328.
Number of shapes registered is 0
Number of parts registered is 328
Number of valid records is 0 of 0
Extracting and storing area edges...
    Tracking line 1.
    Tracking line 2.
    Tracking line 7.
Segmentation fault
So, it's a good old segfault. Is it possible for you to send me this file if it's not confidential?
David
