Is there a regression testing suite for Grass that can be run following
compilation to verify minimum functionality?
James Cameron mailto:quozl@us.netrek.org http://quozl.netrek.org/
subject 'unsubscribe grass5'
Hi James,
such test I wanted to propose last week and already start
to write a small initial script. Such a test system is
urgently required. Please go ahead if you know a concept
how to write such a test system. It is highly appreciated!
Thanks in advance
Markus Neteler
On Thu, 27 Jul 2000, Markus Neteler wrote:
such test I wanted to propose last week and already start to write a small
initial script. Such a test system is urgently required. Please go ahead
if you know a concept how to write such a test system. It is highly
appreciated!
Markus, et al.:
Take a look at the regression code used for PostgreSQL. Perhaps it will be
a source of ideas at a minimum.
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
Making environmentally-responsible mining happen. (SM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
there are already some testing programs in the source code (e. g.
src/libes/gis/TESTS, src/libes/datetime/tests). Not a real regression
testing suite, but may be good as a starting point.
Obviously some data has to be included to do testing. Or some sort of
artificial test data should be created.
What about dejaGNU? Could this be used for providing a test framework?
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de - A.C.Lange@GMX.net
