[GRASS5] releasebranch - help
I wanted to fix one bug in ps.map (src/ps.map/ps.map/cmd/ps_area.c).
In default/devel branch everything seems to be OK. In release branch (?)
which is tagged here: Treleasebranch_11_april_2001_5_0_0
(cmd/CVS/Tag) I had run:
cvs commit -m "shift set to 0 for non LL" ps_area.c
Checking in ps_area.c;
/grassrepository/grass/src/ps.map/ps.map/cmd/ps_area.c,v <-- ps_area.c
new revision: 1.1.4.1; previous revision: 1.1
done
But I cannot check that through cvs-web interface. It is not in
any of following tags (branches?):
releasebranch_5_0_0
releasebranch_500
releasebranch_14_august_2001_5_0_0
grassreleasebranch_5_0_0
I am doing something wrong, could somebody help me?
I know, I am bit late in bugfixing in release branch, but it is important
bug and I had no time (and I have no time) for grass in last moths.
Thanks.
Radim
Hi Radim,
On Wed, Sep 12, 2001 at 02:39:27PM +0200, Radim Blazek wrote:
done
perfect, it reached the right destination.
releasebranch_5_0_0
releasebranch_500
Beware of the CVS web interface!! It is looking at the experimental
branch only [Jan, Bernhard, please either change that or switch it
off].
I just checked with
http://freegis.org/cgi-bin/viewcvs.cgi/grass/src/raster/r.info/cmd/
which I changed two days ago. The change doesn't appear in CVS web,
but is in the right place.
-> don't use and trust the web interface!
Hope to know you back soon :slight_smile:
The viewcvs web interface shows all tags and the MAIN trunk first.
This is correct behaviours. People should know CVS a bit to make use
of all information of viewcvs.
We have to explain it to the rest interested.
  Bernhard
On Wed, Sep 12, 2001 at 02:44:28PM +0200, Markus Neteler wrote:
Hi Radim,
> Hi,
> done
> releasebranch_5_0_0
> releasebranch_500
off].
I just checked with
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
FSF Europe (fsfeurope.org)
