[GRASS5] Resolution of nviz bus error on Mac?
I haven't heard anything since Lorenzo Moretti reported problems running
NVIZ in the current CVS version of GRASS 5.7. This did not have to do with
the WIND3 issue apparently, but generated a bus error.
Has there been any resolution?
Michael
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
I am not sure whether it is the same problem, but nviz crashes when I try
to display a vector file that was converted from site file (the points display
correctly in 2D).(vector file converted from old line vector file works well).
Below is the error message. Tis might have been fixed meanwhile - my nviz
is few weeks old.
I did quite a bit of work with nviz in 5.7 including reviving multiple
dynamic surfaces (such as these
http://skagit.meas.ncsu.edu/~helena/publwork/figs/a57tenslpcn.gif (it is 14MB so you have to wait
for it to load, they are easy to make using file sequence tools
and then creating animated gif using "convert", the animation shows impact of RST tension on lidar-based
surface, curvature and slope).
Everything hat I tried works well except the vector points and for animations, I cannot get it to redraw
at full resolution for files larger than 500x500 - probably an old bug in scripting tool.
Helena
Vector file atmlid99ieesrd@ieee loaded.
Total vect memory = 0 Kbytes
child killed: segmentation violation
     while executing
"exec /home/helena/grasscvs57/grass-5.7.cvs/etc/nviz2.2/NVWISH2.2 -f /home/helena/grasscvs57/grass-5.7.cvs/etc/nviz2.2/scripts/nviz2.2_script lid99.t30..."
     ("eval" body line 1)
     invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name NVIZ >&@stdout"
     invoked from within
"if {$argv == ""} {
#no arguments
eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ >&@stdo..."
     (file "/home/helena/grasscvs57/grass-5.7.cvs/bin/nviz" line 16)
Michael
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
