[GRASS5] Running beta-11.2 with libncurses.so.4
  While the Red Hat package installed just fine (at least, it didn't
complain), it won't run. It's looking for libncurses.so.5, and my system has
libncurses.so.4 installed.
  I'm told that this ncurses-5.2-5.i386.rpm problem is a Red Hat problem:
they build the wrong library number with the latest package. Correcting this
is apparently a very major PITA.
  What I'd like to do is have access to the beta-11.2.src.rpm and rebuild it
on my system. That should link the libncurses.so.4 library and allow the
program to run.
  Will this work? I don't find a .src.rpm on the download page, only the
standard grass5.0beta11.2_Linux_bin.tar.gz.
  I suppose that I can build from scratch, too. What I'm seeking is the most
parsimonious (i.e, simplest, easiest, quickest) way to get a running copy of
GRASS-5 on my system.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
              Making environmentally-responsible mining happen. (SM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
subject 'unsubscribe grass5'
program to run.
Hi Rich,
to stay platform independent the sources are currently in tar.gz.
Just look here:
http://www.geog.uni-hannover.de/grass/download.html
-> Download Source Code for GRASS 5.0beta
   -> Bereich Geographie – Naturwissenschaftliche Fakultät – Leibniz Universität Hannover
Did you look at Baylor?
configure
make
make install
:slight_smile:
Enjoy,
