-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
What's the best way to run multiple commands in GRASS? What I'm doing now is trying to put the tasks to background with the &, but then I still get the input on the console, which gets things really confusing.
Is it possible, for example, to start another GRASS command line on another terminal?
The reason why I want to do this is to be able to process two different modules simultaneously in an openMOSIX cluster and be able to see where each one is standing.
Gualter Barbas Baptista
gualter@netcabo.pt ICQ# 8106393 jabber.org: gandhiano
GAIA - Grupo de Acção e Intervenção Ambiental
ae-gaia@students.fct.unl.pt
Portugal
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.0.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE9WEhcNKPP62B6z9cRAsysAJ9YSuhs57uqjhAVQpPlj3SV2G3dcACgzOmZ
pxSjmseGOGZBvihZm4w1+OY=
=QGXJ
-----END PGP SIGNATURE-----
another terminal?
The GRASS startup scripts won't allow multiple sessions for the same
user (to prevent race conditions in reading/writing $GISRC), or for a
given mapset (to prevent race conditions in reading/writing the
mapset; note that this applies not just to maps, but to the WIND,
[CUR]GROUP and [CUR]SUBGROUP files and to temporary files).
You can bypass the startup, and just set the necessary environment
variables yourself, e.g.
GISBASE=/opt/grass5
GISRC=$HOME/.grassrc5
TCLTKGRASSBASE=$GISBASE/tcltkgrass
GRASS_GNUPLOT=gnuplot
GRASS_PAGER=cat
GRASS_PERL=perl
GRASS_TCLSH=tclsh
GRASS_WISH=wish
PATH=$GISBASE/bin:$GISBASE/scripts:$PATH
MANPATH=$GISBASE/man:$MANPATH
LD_LIBRARY_PATH=$GISBASE/lib:$LD_LIBRARY_PATH
PAGER=cat
export GISBASE GISRC TCLTKGRASSBASE
export GRASS_GNUPLOT GRASS_PAGER GRASS_PERL GRASS_TCLSH GRASS_WISH
export PATH MANPATH LD_LIBRARY_PATH
export PAGER
You should give each process a different $GISRC file, using different
mapsets (and, if applicable, different monitors).
