[GRASS5] s.to.rast question
Does the s.to.rast write a temporary file somewhere to check on the progress?? I am working with a large file and am wondering if it is still running properly or not. I let it run overnight last night, and came into find it still running, and started again this morning about 0900 and it continues to run at this time (1110).
        LTJG Kevin Slover,NOAA   GIS Specialist/Meteorologist/Oceanographer
              Tropical Prediction Center/National Hurricane Center
                    11691 SW 17th Street Miami FL 33165
                 Work: (305) 229-4456 Fax : (305) 553-1264
Yes, it writes a temp file, and after that copy it to the real raster file.
since it uses G_tempname(), you should find it at the habitual location.
Michel WURTZ - DIG - Maison de la télédétection
               500, rue J.F. Breton
               34093 MONTPELLIER Cedex 5
