[GRASS5] Segfault in v.in.tig.lndmk
Grass Developers,
I found a Segfault in v.in.tig.lndmk. Here is a summary of my fault case and a patch that fixed this for me.
My distro and grass source
Debian/GNU Linux; grass CVS HEAD; (I believe the release branch should also have same fault - have not tested this ).
Data used for fault case:
http://www.census.gov/geo/www/tiger/tiger2k/ny/tgr36105.zip
Setup this location:
mapset: census
UTM zone 18
n=4805100
s=4440000
w=279100
e=743900
nsres=100
ewres=100
Make this file *fault.txt*
.points hospitality
D27
.end
.exit
***** End of fault.txt
Run this grass command
v.in.tig.lndmk t1=/dir/to/unziped/TGR36105.RT1 input=crash.txt
My Analysis
the Site_head info struct in open_site_file() from points.c failed to fully initialize the structure. The info.stime if non null garbage is taken by G_site_put_head() to me a valid structure.
This Patch fully initializes the structure to NULLs.
RCS file: /home/grass/grassrepository/grass/src/mapdev/v.in.tig.lndmk/points.c,v
retrieving revision 1.2
diff -c -r1.2 points.c
*** points.c 12 Jan 2001 08:16:28 -0000 1.2
--- points.c 14 Feb 2002 19:20:25 -0000
*** 42,47 ****
--- 42,53 ----
    FILE *fp1;
    Site_head info;
+ info.name = NULL;
+ info.desc = NULL;
+ info.form = NULL;
+ info.labels = NULL;
+ info.stime = NULL;
+ info.time = NULL;
    if (sitefile == NULL)
      if ((sitefile = G_fopen_sites_new (site_name)) == NULL)
-Tom Rake
_________________________________________________________________
Send and receive Hotmail on your mobile device: http://mobile.msn.com
Thank, Tom!
I have applied the fix to both experimental and release branch.
On Thu, Feb 14, 2002 at 02:47:41PM -0500, Tom Rake wrote:
Grass Developers,
mapset: census
UTM zone 18
n=4805100
s=4440000
w=279100
e=743900
nsres=100
ewres=100
.points hospitality
D27
.end
.exit
My Analysis
RCS file:
*** 42,47 ****
--- 42,53 ----
    FILE *fp1;
    Site_head info;
+ info.name = NULL;
+ info.desc = NULL;
+ info.form = NULL;
+ info.time = NULL;
-Tom Rake
