[GRASS5] shade.rel.sh bug?
the shade.rel.sh script does IMHO not work properly any more.
If i create a shaded relief in plain areas (even surfaces/no slope)
there are NULL-holes in the raster. My DEM has no NULL-values.
I think that this comes from different handling of division by zero?
This has maybe a very simple solution (if-clause in the mapcalc
function?), but i don't know which.
I'll report this to the RT if i get no feedback for a solution.
Just removed my grass4.3 setup, so that i can no longer test.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de - A.C.Lange@GMX.net
subject 'unsubscribe grass5'
On Fri, Jan 12, 2001 at 04:22:56PM +0100, Andreas Lange wrote:
Hi Andreas,
I have already a fix - will check in now.
In a few minutes...
> Hi,
Hi Andreas,
In a few minutes...
Done :slight_smile:
cvs up src/scripts/shells/shade.rel.sh
Please try. Congrats evetually to David Finlayson <david_finlayson@yahoo.com>
Thank you very much.
Works now without any problems!
cu,
Andreas
> > Hi,
> Hi Andreas,
> In a few minutes...
Done :slight_smile:
