[GRASS5] shape file limit with v.in.org.all
I have an odd script question. I am using a script v.in.ogr.all
#!/bin/bash
#test to see if script is being run from GRASS
if test "$GISBASE" = ""; then
         echo "You must be in GRASS to run this program"
         exit
fi
for MAP in `ls ~/projects/mn_dnr/shape_files/forties/county/*.shp`; do
     v.in.ogr -o dsn=~/projects/mn_dnr/shape_files/forties/county/ output=`ba\
sename $MAP .shp` layer=`basename $MAP .shp`;
done
to import a bunch (>100) shape files. When I run the script on the whole directory of shape files, I get the error:
ERROR 4: Unable to open /Network/Servers/truffula.fr.umn.edu/Volumes/disk1/home1/kwythers/projects/mn_dnr/shape_files/forties/county/wrig_forties.shx or /Network/Servers/truffula.fr.umn.edu/Volumes/disk1/home1/kwythers/projects/mn_dnr/shape_files/forties/county/wrig_forties.SHX.
repeated for every shape file. However, if I run the same script on just a few files, the world is cool. So far I have run it on 1 file, 3 files, 6 files, and 20 files. I am about to try 50 or so files. Has anyone see this kind of behavior before?
Kirk
#!/bin/bash
        exit
fi
output=`ba\
done
wrig_forties.SHX.
Kirk,
I guess that the parameter length created by `ls *...` is
exceeding a Un*x limit (for the shell or whatever).
You may try to rewrite it to first go into the
directory, then run the loop in that directory.
#!/bin/bash
        exit
fi
output=`ba\
done
wrig_forties.SHX.
Kirk,
Thanks Markus. I have another large collection of shape files to read in today. I'll give it a go. I never figured out exactly what the limit was (something between 25 and 100 files, I would guess).
Kirk:
>> *.shp`; do
>file, > 3 files, 6 files, and 20 files. I am about to try 50 or so
>files. Has > anyone see this kind of behavior before?
Markus:
Kirk again:
You are probably past this now, but for the greater understanding &
future scripts..
I think what Markus was getting at is that it wasn't a file limit, but a
string character limit. cd'ing to the directory will remove the
directory from each file from the `ls` string (as you do with basename
later), which means you can fit a lot more names in the 4096? chars you
have available for the shell to work with.
"~/projects/mn_dnr/shape_files/forties/county/" * 100 maps is an extra
4500 chars. That would put you over the 4096 limit. Alternatively to
"cd" first, running 'basename .shp' in the `ls` step would mean a
savings of an extra 4 chars per map, which may help for a huge number of
maps.
hope it all makes sense now,
Hamish
