On Friday, June 1, 2001, at 02:39 PM, Frank Warmerdam wrote:
Jeshua,
OK, I have fixed it up so it builds fine from source now. Could you test
/Users/frankw/gdal/libgdal.1.1.dylib with GRASS's r.in.gdal and see if it
works? You can set your DYLD_LIBRARY_PATH to point to the directory and
it will hopefully work. If not, let me know (and where your GRASS build is).I have put this build on my GRASS page, so if it works we can proceed to
announce it.
Thanks Frank!
I installed your gdal lib, and when attempting to compile r.in.gdal, I get a "Undefined symbols:
_GBGetSymbol" error.
Any ideas?
Here is the full-related message:
gcc -o /usr/src/grass/dist.powerpc-apple-
darwin1.3.3/etc/bin/cmd/r.in.gdal OBJ.powerpc-apple-darwin1.3.3/main.o OBJ.powerpc-apple-darwin1.3.3/gbgetsymbol.o OBJ.powerpc-apple-
darwin1.3.3/gdalbridge.o OBJ.powerpc-apple-darwin1.3.3/make_loc.o /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.3.3/libgis.a /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.3.3/libI.a -ldl -I/usr/include -L/usr/lib -lz
/usr/bin/ld: Undefined symbols:
_GBGetSymbol
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
