Hello all
I changed the src/CMD/generic/POST_INSTALL.sh file so that it prints the
absolute path to the newly created bin.$ARCH/gmake5 and
bin.$ARCH/gmakelinks5 giving the proper command line for users to use to
compile Postgres, or ODBC, or the PNG driver. Please check the next time
you run "make" that the paths that are printed are correct. Also. please
let me know if you have any problems.
Thank you.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
From neteler Tue May 29 09:11:52 2001
Return-Path: <neteler>
Received: by hgeo02.geog.uni-hannover.de (SMI-8.6/SMI-SVR4)
id JAA18364; Tue, 29 May 2001 09:11:52 +0100
Date: Tue, 29 May 2001 09:11:51 +0100
From: Markus Neteler <neteler@geog.uni-hannover.de>
To: Mike Thomas <miketh@brisbane.paradigmgeo.com>
Cc: grass5 developers list <grass5@geog.uni-hannover.de>
Message-ID: <20010529091151.J13947@hgeo02.geog.uni-hannover.de>
Mail-Followup-To: Mike Thomas <miketh@brisbane.paradigmgeo.com>,
References: <000d01c0e352$fbf49ef0$0cb4a8c0@brisbane.paradigmgeo.com> <20010523093007.A8863@hgeo02.geog.uni-hannover.de> <009301c0e742$0ea9f110$0cb4a8c0@brisbane.paradigmgeo.com> <20010528083932.K12157@hgeo02.geog.uni-hannover.de> <00b101c0e7e1$84413e20$0cb4a8c0@brisbane.paradigmgeo.com>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
User-Agent: Mutt/1.2.5i
In-Reply-To: <00b101c0e7e1$84413e20$0cb4a8c0@brisbane.paradigmgeo.com>; from miketh@brisbane.paradigmgeo.com on Tue, May 29, 2001 at 11:48:48AM +1000
Subject: [GRASS5] Re: WinGrass binary.
Sender: grass5-admin@geog.uni-hannover.de
Errors-To: grass5-admin@geog.uni-hannover.de
X-BeenThere: grass5@geog.uni-hannover.de
X-Mailman-Version: 2.0.5
Precedence: bulk
List-Help: <mailto:grass5-request@geog.uni-hannover.de?subject=help>
List-Post: <mailto:grass5@geog.uni-hannover.de>
List-Subscribe: <http://www.geog.uni-hannover.de/mailman/listinfo/grass5>,
<mailto:grass5-request@geog.uni-hannover.de?subject=subscribe>
List-Id: GRASS 5 Developers mailing list <grass5.geog.uni-hannover.de>
List-Unsubscribe: <http://www.geog.uni-hannover.de/mailman/listinfo/grass5>,
<mailto:grass5-request@geog.uni-hannover.de?subject=unsubscribe>
List-Archive: <http://www.geog.uni-hannover.de/pipermail/grass5/>
Status: O
Content-Length: 4863
Lines: 146
Hi Mike,
(cc to grass5)
On Tue, May 29, 2001 at 11:48:48AM +1000, Mike Thomas wrote:
Hi again.
SUMMARY: I fixed the NVIZ and PNGDriver link problems, but left the
r.fill.dir one till later. Fixes below. Made a new installation which is
available as noted in my other email today.
Thanks - download is running...
NVIZ is compiled, but won't run unless you put init.tcl in a new directory -
"<GRASS-INSTALL-DIR>/etc/share/tcl8.0".After fixing this, when run from tcltk, it then gives a usage message in an
XTERM and stops gracefully.
[below more]
DETAILS:
> > (http://www.geog.uni-hannover.de/grass/grass5/source/), rather than the
> > CVS pre-release tag, which has given me some inconsistent build results.
> mhhh, that's surprising as it should be identical.My guess is that when I did a CVS update in the tagged source I may have
accidentally brought in files from other parts of the CVS.Is just "cvs update" OK in the tagged source?
Check if you have the Treleasebranch_11_april_2001_5_0_0 applied (check
CVS/Entries). If so, you can run
cvs update -dP
to update it (last night another Xdriver fix from Glynn appeared).
> > To avoid further delays, r.fill.dir, PNGDRIVER and NVIZ are not in the
> > distribution, as I had troubles building each of them.
> Please be so kind and send the error messages, especially of r.fill.dir.The configure seems to have incorrectly dealt with "values.h". I'll look
into it today.
That's easy to fix:
/cygdrive/e/cvs/grass5.0.0pre1/src/raster/r.fill.dir
mkdir OBJ.i686-pc-cygwin
make -f OBJ.i686-pc-cygwin/make.rulesmake[1]: Entering directory
`/cygdrive/e/cvs/grass5.0.0pre1/src/raster/r.fill.dir'
gcc -g -O2 -I/cygdrive/e/cvs/grass5.0.0pre1/src/include -c main.c -o
OBJ.i686-pc-cygwin/main.o
In file included from main.c:54:
tinf.h:3: values.h: No such file or directory
Change it to "limits.h":
Index: tinf.h
RCS file: /grassrepository/grass/src/raster/r.fill.dir/Attic/tinf.h,v
retrieving revision 1.1.2.2
diff -r1.1.2.2 tinf.h
3c3
< #include <values.h>
#include <limits.h>
values.h is the old, obsolete name for limits.h. I have updated in CVS as
well.
> For PNGDriver I assume problems with libgd, and NVIZ?
PNGDriver's Gmakefile puts ${PNGLIB} before ${GDLIB} which means that the
libgd references to libpng don't get resolved at link time. I swapped them
around and it linked fine. I'll redo the binary package. The fixed line
is:$(GISBASE)/driver/PNG: $(OFILES) ${DRIVERLIB} ${GISLIB}
${CC} $(LDFLAGS) -o $@ $(OFILES) ${DRIVERLIB} ${GISLIB} $(GRAPH) $(ZLIB)
${GDLIB} ${PNGLIB} $(MATHLIB) $(XDRLIB)
Thanks, fixed as well in CVS.
Why didn't anyone report that problem?
Well, the gcc compiler seem to be able to live with the reversed order.
Both versions compile well here. Anyway, it is reversed now.
Built now and and put in the binary package.
NVIZ -
Two problems -
1. Some libX11 symbols were not being resolved. To
"NVIZ2.2/src/gmakefile.in" I made this change (added $XLIB, probably just
needs reordering of the OGLLIB macro, but this is quicker):nvwish: $(OBJS) $(VECTLIB) $(BITMAPLIB) $(LINKMLIB)
$(CC) -g -o $@ $(OBJS) $(LDFLAGS) $(SURFLIB) $(IMGLIB) \
$(BITMAPLIB) $(LINKMLIB) $(VECTLIB) \
$(GISLIB) $(MATHLIB) $(XDRLIB) \
$(LIBDIR)/libdatetime.a $(XTRA_LDFLAGS) -ltiff $(XLIB)2. The install target in "NVIZ2.2/Gmakefile" fails to mv the nvwish.exe, as
it leaves out the .exe extension. This mod at the end of the target does
the job:install:
if test -f "src/nvwish" ; then mv src/nvwish.exe
^^^^- without .exe
$(INSTALL_DIR)/$(NVWISH_VER) ; fi
if test -f "src/nvwish.exe" ; then mv src/nvwish.exe
Thanks, both fixes are applied to CVS. However, doesn't need $(NVWISH_VER)
the .exe extention as well for winGRASS (second case)? Something like:
if test -f "src/nvwish.exe" ; then mv src/nvwish.exe $(INSTALL_DIR)/$(NVWISH_VER).exe ; fi
> > v.digit /backdrop cell map hangs
> Oops. How does it hang? Does it crash or doesn't it display the map?The entire bash session hangs without displaying the map. I have to kill
the shell and v.digit.I tried commenting out the loop in "drawcell()" but it still hangs. My wife
got cranky so I had to stop and look after the children after that! I
haven't had time at work yet to go further on this problem.Time to get back to making a living for a few hours.
Mike Thomas
Perhaps Glynn could recommend on the v.digit problem.
Thanks, Mike, for your fixes,
