[GRASS5] snprintf and other compile errors on IRIX
That last change to v.in.mif worked. This means all currently-enabled
modules compile OK on IRIX now!
On Fri, 26 Apr 2002, Glynn Clements wrote:
> > > Compilation error in module: src/mapdev/v.in.mif (ignored)
> > > cc -I/indigo-disk2/grass/grass/src/include -g
> > > -I/indigo-disk2/grass/doom.ee.qub.ac.uk/include -c lex.yy.c -o
> > > OBJ.mips-sgi-irix6.2/lex.yy.o
> > > cfe: Error: mif.l, line 572: Syntax Error
> > > {blank} |
> > > make: *** [OBJ.mips-sgi-irix6.2/lex.yy.o] Error 1
> > I'm not sure what it's complaining about here; if you can find out
> > exactly what the error is, I'll commit the fix.
> Still don't have a clue about this, sorry
Try changing the lines:
<*>{whitespace} |
  {blank} |
    {end} ;
to:
<*>{whitespace} |
<*>{blank} |
<*>{end} ;
