[GRASS5] Solaris GRASS 5.1, shared libraries, external PROJ
Dear GRASS Developers,
I have at last successfully built GRASS 5.1 (2003_09_06) on Solaris 9. Thank you to everyone who gave me advice.
The ps/ps.map/Makefile needs Proj includes:
EXTRA_INC = $(VECT_INC) $(PROJINC)
In order to run grass51, I needed to set LD_LIBRARY_PATH to find the shared libraries in dist.$ARCH/lib and the external PROJ.4 lib. This was not mentioned in the INSTALL file.
Would it be OK to add --with-proj=PROJDIR to configure? PROJDIR is the path to PROJ.4 (above bin, include, and lib). Then configure could look for include and lib under PROJDIR and lib/proj/Makefile could use NAD2BIN = $(PROJDIR)/bin.
- Bev
Bev Wallace
Lockheed Martin, Sunnyvale, CA, USA
beverly.t.wallace@lmco.com
OK, done in cvs.
This is done in etc/Init.sh:
if [ ! "$LD_LIBRARY_PATH" ] ; then
  LD_LIBRARY_PATH=$GISBASE/lib
  export LD_LIBRARY_PATH
else
  LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$GISBASE/lib
fi
this section is identical to 5.0, but why it is exported only
in the first case, would not be better
else
fi
and is it necessary to test if $LD_LIBRARY_PATH is defined,
is it ':/some/path' error?
Maybe you are not running GRASS within regular session?
BTW, you can run applications without $GISRC and user mapset.
(example in GRASS++ and QGIS)
Radim
else
fi
else
fi
Yes; there is no point setting LD_LIBRARY_PATH if it isn't exported.
Potentially; I think that it's best to be safe.
Also, using shared libraries may cause problems for tcltkgrass when it
runs a program in an xterm. If xterm is setuid (which is common),
LD_LIBRARY_PATH may end up being unset automatically.
