We have made another attempt to compile the CVS version on Solaris -
this time it is giving different errors and unfortunatelly it still does
not
compile - this is probably more Solaris problem rather than GRASS
problem
the error and config log files are at
http://www2.gis.uiuc.edu:2280/modviz/temp/solaris.compile
If you see anything obvious, please let us know,
Helena
subject 'unsubscribe grass5'
Helena,
What version of Solaris are you trying? I'm getting different output in 2.6
vs 7 here that point to what look like library organization troubles in
Solaris (32-bit). 64 does better but still has some different errors.
Bruce
not
problem
Helena
Helena,
not
problem
Yes, I think so:
configure: In function 'main':
configure:2565: structure has no member named 'maxy'
configure: failed program was:
#line 2559 "configure"
#include "confdefs.h"
#include <curses.h>
WINDOW w;
int main() {
w.maxy = 0;
; return 0; }
This indicates problems with your curses library. Bob Covill had similar
problems and fixed them by upgrading to ncurses5.
A wish: If src/libes/gis is failing, please send the local error as
well
cd src/libes/gis
gmake5
Most other errors will be related to the missing libgis.a.
So, please upgrade the oldish curses on Solaris to ncurses5.
Regards
