Palle Haastrup <palle.haastrup@jrc.it>, who kindly prepared
SUN/Solaris binaries for the GRASS community (today), faces
a few compile problems. Eventually they are GRASS code
related?
Here the needed info, I have no idea about this. Due to
this these modules are not included in the binary package.
Reading specs from /usr/local/lib/gcc-lib/sparc-sun-solaris2.8/3.0.2/specs
Configured with: ../configure --with-as=/usr/local/bin/as
+--with-ld=/usr/local/bin/ld --enable-libgcj
Thread model: posix
gcc version 3.0.2
SRC = /sd5/sw2001/grass/grass5.0.0pre3/src
CMD = /sd5/sw2001/grass/grass5.0.0pre3/src/CMD
UNUSED = /sd5/sw2001/grass/grass5.0.0pre3/unused
HEADER = head.sparc-sun-solaris2.8
ARCH = sparc-sun-solaris2.8
GISBASE = /sd5/sw2001/grass/grass5.0.0pre3/dist.sparc-sun-solaris2.8
VERSION = 5.0.0pre3 January 2002
/sd5/sw2001/grass/grass5.0.0pre3/src/display/d.histogram
make -f OBJ.sparc-sun-solaris2.8/make.rules
/usr/local/bin/gmake5 -all
/sd5/sw2001/grass/grass5.0.0pre3/src/display/d.histogram/cmd
make[1]: Entering directory `/sd5/sw2001/grass/grass5.0.0pre3/src/display/d.histogram/cmd'
gcc -I/sd5/sw2001/grass/grass5.0.0pre3/src/include -g -O2 -c draw_slice.c -o OBJ.sparc-sun-solaris2.8/draw_slice.o
draw_slice.c: In function `draw_slice':
draw_slice.c:106: Internal compiler error in change_address, at emit-rtl.c:1635
Please submit a full bug report,
with preprocessed source if appropriate.
See <URL:http://www.gnu.org/software/gcc/bugs.html> for instructions.
make[1]: *** [OBJ.sparc-sun-solaris2.8/draw_slice.o] Error 1
make[1]: Leaving directory `/sd5/sw2001/grass/grass5.0.0pre3/src/display/d.histogram/cmd'
make: *** [all] Error 1
/sd5/sw2001/grass/grass5.0.0pre3/src/mapdev/v.out.moss
gcc -I/sd5/sw2001/grass/grass5.0.0pre3/src/include -g -O2 -c area_to_moss.c -o OBJ.sparc-sun-solaris2.8/area_to_moss.o
area_to_moss.c: In function `area_to_moss':
area_to_moss.c:144: Internal compiler error in change_address, at emit-rtl.c:1635
make: *** [OBJ.sparc-sun-solaris2.8/area_to_moss.o] Error 1
/sd5/sw2001/grass/grass5.0.0pre3/src/raster/r.slope.aspect
/sd5/sw2001/grass/grass5.0.0pre3/src/raster/r.slope.aspect/cmd
make[1]: Entering directory `/sd5/sw2001/grass/grass5.0.0pre3/src/raster/r.slope.aspect/cmd'
gcc -I/sd5/sw2001/grass/grass5.0.0pre3/src/include -g -O2 -c main.c -o OBJ.sparc-sun-solaris2.8/main.o
main.c: In function `main':
main.c:1303: Internal compiler error in change_address, at emit-rtl.c:1635
make[1]: *** [OBJ.sparc-sun-solaris2.8/main.o] Error 1
make[1]: Leaving directory `/sd5/sw2001/grass/grass5.0.0pre3/src/raster/r.slope.aspect/cmd'
/sd5/sw2001/grass/grass5.0.0pre3/src.contrib/CERL/raster/r.hydro.CASC2D
gcc -I/sd5/sw2001/grass/grass5.0.0pre3/src/include -g -O2 -c CASC2D.c -o OBJ.sparc-sun-solaris2.8/CASC2D.o
CASC2D.c: In function `main':
CASC2D.c:2995: Internal compiler error in change_address, at emit-rtl.c:1635
make: *** [OBJ.sparc-sun-solaris2.8/CASC2D.o] Error 1
/sd5/sw2001/grass/grass5.0.0pre3/src.contrib/NPS/r.out.elas
main.c:815: Internal compiler error in change_address, at emit-rtl.c:1635
make: *** [OBJ.sparc-sun-solaris2.8/main.o] Error 1
