[GRASS5] some BUGS/missing features
i wish everyone here a happy new year 2001!
While doing some work with GRASS5.0(beta11/CVS) i discovered some minor
BUGS and some missing features.
r.poly:
r.poly respects the actual region settings, while r.line does not.
I think that at least for the new vector lib every module should either
use the actual region settings or ignore them. Not sure which is better.
s.buffer:
s.buffer is missing, but html-page is still there. s.buffer is IMHO no
longer needed, this is the same than v.circle?
v.circle:
v.circle does echo an error with spearfish - bugsites data, but seems to
work ok. It says something about wrong attributes?
s.to.vect:
s.to.vect does not find bugsites@PERMANENT when in users mapset (e. g.
'andreas'), but does not flag this error when in interactive mode. The
module trys always to find the file in the actual mapset, not in the
@PERMANENT mapset. Should be a simple fix.
v.patch:
v.patch uses the region info from the first vector map header and
ignores the users region settings. As the region info from the map
header is not reliable, this should be upgraded in a future vector lib
redesign.
v.to.rast:
v.to.rast does ignore some areas when used in a very small region.
Something not correctly working. I have to further investigate this. May
be some problem with the boundary resolving.
d.save:
d.save does not work with text output (d.text), text is not saved.
d.redraw (script):
d.redraw does not work with multiple frames and does not work if d.text
is used (see d.save error).
d.what.rast:
If using d.what.rast slope@PERMANENT in a users mapset (e. g.
'andreas'), it get the error: WARNING: Can't open header file for [slope
in andreas], but works otherwise correct. I assume the header is not
searched in the correct dir.
v.what/d.what.vect:
v.what -i and d.what.vect are very similar and could be merged to one
module? Not quite sure here.
r.what/d.what.rast:
r.what and d.what.rast are (not really) similar and could be merged to
one module?
gnuplot:
v.to.gnuplot is missing, instead of html-page which is still there.
g.gnuplot is missing, instead of html-page, which is still there. (can't
say if gnuplot inside GRASS is really useful).
The old g.gnuplot works by drawing in a GRASS monitor, which could be
useful for creating histograms etc.
v.alabel/v.llabel:
v.alabel does bulk labeling of areas, v.llable does bulk labeling of
line features. But there is no module to bulk label point features (site
vectors in GRASS terminology). This function is needed if you want to
intersect point features with area features (point-in-polygon test).
v.cutregion:
A module v.cutregion would be very handy to cut a vector map to the
actual region. When i import from ascii vector files all vectors get
imported, irrespectable if they fall into the current region or the
whole GRASS region. This stems from the handling of the ascii header i
think. With the new vector lib this could be handled correctly, but as a
intermediate fix a module v.cutregion would be very useful.
Please tell me if i should feed the above bugs/missing features into the
request tracker.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de - A.C.Lange@GMX.net
subject 'unsubscribe grass5'
Hi again,
On Thu, Jan 04, 2001 at 02:35:33PM +0100, Andreas Lange wrote:
r.poly:
All raster modules are sensitive to the actual region settings. I just
have fixed r.line (io.c): G_set_window() should have been G_get_window().
Please try the updated version.
s.buffer:
v.circle:
Please try v.bubble - should be an improved version of v.circle.
If v.bubble is the best, let's remove s.buffer and v.circle and rename
v.bubble to v.circle.
s.to.vect:
Mhhh, volunteers?
v.patch:
redesign.
David, Radim?
v.to.rast:
Thanks in advance!
d.save:
-> please report in out new RT...
d.redraw (script):
-> please report in out new RT... When Huidae is back online, he might take
a look.
d.what.rast:
Perhaps similar to s.to.vect bug?
v.what/d.what.vect:
Yes! Same thing with r.what/d.what.rast.
Or we decide that [rv].what are for script programming and
d.what.[vect|rast] are for interactive usage. Should get comparable module
behaviour.
r.what/d.what.rast:
one module?
see above.
gnuplot:
Maybe we better implement "gdchart"?
v.alabel/v.llabel:
v.slabel? I have added a note into TODO.
v.cutregion:
I think this is on the way for 5.1 (David, Radim?).
request tracker.
see above :slight_smile:
Thanks for your comments,
Markus Neteler wrote:
> r.poly:
On Thu, Jan 04, 2001 at 05:10:04PM +0000, Markus Neteler wrote:
> s.buffer:
> v.circle:
Well, I can report a small problem I've had with v.bubble. When
generating the buffers based on an attribute, it seems the smallest one
ends up with a zero area degenerate. That wasn't the expected behavior.
I tried to write a version of s.buffer implementing the reported
features from the man page as well as the features of v.circle and
v.bubble. The problem I had was figuring out how to handle overlapping
vector areas and dissolving the common boundaries. It wasn't enough
just to generate a circle and put the area label in the middle, since
v.support would often choke on the results. The available library
routines for a new vector layer weren't much help either.
> s.to.vect:
Mhhh, volunteers?
I'll have a look since I worked on that before. Note, s.to.vect is also
broken if the "category" number is a float (since it can't be a float in
the vector world). I'll see if I can work around this as well.
Eric G. Miller <egm2@jps.net>
> r.poly:
Vectors will ignore region except conversion into raster. I think that all vector
modules ignore region now.
> v.patch:
> redesign.
David, Radim?
As I wrote in mail "new vector2" I propose move bounding box from dig
into dig_plus.
> v.what/d.what.vect:
behaviour.
I think always merge modules if possible.
> v.alabel/v.llabel:
I want merge into v.category in g51 (and add: delete category, change
category number, ...)
(always merge modules if possible)
> v.cutregion:
Cutting areas is not so simple and we have already v.cutter.
I think that additional option for v.cutter
-r use current region insted of cutter map
should help.
Radim
> > r.poly:
Well, but here we have raster-> vecktor conversion. So sensivity should be
o.k. as the source is raster.
> > v.patch:
> > redesign.
> David, Radim?
into dig_plus.
> > v.what/d.what.vect:
> behaviour.
> > v.alabel/v.llabel:
> > v.cutregion:
should help.
Yes, such an option for v.cutter would be good (and additionally have
v.cutter copying the labels to the new file).
> r.poly:
This doesn't work. I think now that if r.poly uses the region settings,
r.line should too.
The vector modules can not use the current region setting, as this would
require an extra round of cutting and probably affect topology in
unwanted ways.
> v.patch:
> redesign.
David, Radim?
This is more a long-term wish. No need to implement this with the old
vector lib IMHO.
> v.to.rast:
Thanks in advance!
Will look again now.
> d.what.rast:
> v.what/d.what.vect:
behaviour.
> r.what/d.what.rast:
> one module?
see above.
I think now that r.what/v.what should be shell-style and d.* interactive
modules. No need to have the interactive part in the r./v. modules.
Then the d.* modules could check for display availability. It is
important IMHO that the output of both d and r/v modules is identical.
Reported to the request tracker.
> v.cutregion:
I am aware that there are many improvements on the way. But i have to do
my work right now.
So i need a solution that works.
I wrote a shell script for creating a vector bounding box for the
current region settings and a second script for cutting the actual
region from this.
If there is general need for both scripts please tell me.
> request tracker.
cu,
Andreas
On Fri, Jan 12, 2001 at 01:10:39PM +0100, Andreas Lange wrote:
> > r.poly:
r.line should too.
Here r.line works perfectly now on Linux with any region setting.
I guess you missed to run "make install" or so?
unwanted ways.
Yes. Radim and David already have some ideas for this for 5.1.
> > v.patch:
> > redesign.
> David, Radim?
vector lib IMHO.
I agree - that's for 5.1.
> > v.what/d.what.vect:
> behaviour.
> > r.what/d.what.rast:
> > one module?
> see above.
Definitly! Your proposal sounds good to me.
> > v.cutregion:
my work right now.
region from this.
At least I would like to have such a script. Intersecting and cutting is not
at it's best at time...
> r.line should too.
It works now. I think the problem was that i missed the update, couldn't
compile because of the other error. Thanks a lot.
> > > v.what/d.what.vect:
> > behaviour.
> > > r.what/d.what.rast:
> > > one module?
> > see above.
If i find time, i will try to fix it the way described, as i already
worked on d.what.(vect|rast).
> > > v.cutregion:
> my work right now.
> region from this.
There are still problems with v.cutter to resolve, this was discussed on
grasslist recently. Sometimes it doesn't work properly. Don't know if i
can check the script in.
cu,
Andreas
