[GRASS5] some bugs
just to report some minor bugs:
- g.mlist does not work on IRIX.
It just puts out a long listing of fragments of the shell script itself.
Had no time to look into that.
- with d.pan and d.zoom the color of vectors is always restored white.
If you draw a map with a e. g. green vector and zoom/pan, the vector is
re-drawn, but always white instead of the initial green.
There must be something wrong with the R_pad contents, as d.save puts
out the correct color with the vector before calling d.zoom/d.pan, but
afterwards the color is white even in the pad structure, so that d.save
puts out "d.vect vect=vect@PERMANENT color=white".
cu later,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de - A.C.Lange@GMX.net
subject 'unsubscribe grass5'
