[GRASS5] Some CVS commit statistics
FYI - here some CVS commit statistics. Of course commits are
not the best measure, maybe someone could do an analysis
based on changed lines of code?
M.
CVS analysis from 6 Nov 2003.
GRASS 5.0/5.3-CVS:
2000:
Contributors sorted by name:
alex 10
andreas 138
bernhard 21
bill 2
cho 405
david 106
eric 119
frankw 16
jan 28
job 3
john 57
justin 125
markus 1833
michel 24
radim 75
2962 total (15 contributors)
2001:
alex 36
andreas 75
bernhard 2
bob 68
cho 219
david 26
eric 110
frankw 24
glynn 272
jan 2
john 6
justin 87
malcolm 7
markus 2017
michel 4
mike 19
radim 27
3001 total (17 contributors)
2002:
alex 105
andreas 46
bernhard 11
bob 4
cho 61
david 10
eric 69
frankw 5
glynn 396
markus 643
michel 9
mike 5
moritz 5
radim 52
roger 38
1459 total (15 contributors)
2003
alex 5
bernhard 9
bob 28
cho 2
eric 9
glynn 87
hamish 155
helena 4
markus 391
mike 16
paul 95
radim 10
811 total (12 contributors)
GRASS 5.1/5.7 statistics:
2000:
markus 5
radim 1
6 total (2 contributors)
2001:
david 1
markus 7
radim 23
31 total (3 contributors)
2002:
alex 21
glynn 3
markus 149
radim 263
roberto 49
485 total (5 contributors)
2003
alex 17
bob 9
cho 1
glynn 2
hamish 13
markus 619
paul 53
radim 380
1094 total (8 contributors)
GRASS-Web-CVS statistics
2001:
markus 33
33 total (1 contributors)
2002:
andreas 1
bernhard 18
carl 1
helena 1
markus 545
moritz 4
radim 4
serek 4
578 total (8 contributors)
2003
bernhard 5
helena 11
markus 289
moritz 7
paul 5
radim 4
321 total (6 contributors)
Even the changed lines of code only have a limited meaning.
Sometimes it takes very long to change just one line
and the other way round.
Anyway those number do have some value.
It clearly shows that Markus is leading the pack by a far measure!
It is time again to say
  THANKS Markus for the great work on GRASS!
Also we could use more developers as always.
The number has not significantly increased with some people
dropping out and some joining in.
It seems that some developers move activities from 5.0/5.3 towards 5.7
over time. This seems to be a good sign.
Regarding web commits, we gained one active person,
but also could use more here.
  Bernhard
To make it a bit more useful: Let's look only at the
*number* of contributors with a significant number of
commits.
Considering only developers with >= 24 commits/year
(2 per month, of course an arbitrary threshold):
GRASS 5.0/5.3-CVS:
2000:
andreas 138
cho 405
david 106
eric 119
jan 28
john 57
justin 125
markus 1833
michel 24
radim 75
10 contributors
2001:
alex 36
andreas 75
bob 68
cho 219
david 26
eric 110
frankw 24
glynn 272
justin 87
markus 2017
radim 27
11 contributors
2002:
alex 105
andreas 46
cho 61
eric 69
glynn 396
markus 643
radim 52
roger 38
8 contributors
2003
bob 28
glynn 87
hamish 155
markus 391
paul 95
5 contributors
2000:
0 contributors
2001:
0 contributors
2002:
markus 149
radim 263
roberto 49
3 contributors
2003
markus 619
paul 53
radim 380
3 contributors
(only me)
This useless statistics, but showing some trend?
