[GRASS5] some new r3.* modules and updates in grass6.1-cvs
i've made some changes to the following modules and implemented a new one in the current grass6.1-cvs:
Updates:
g.mremove
* added rast3d support
r3.to.rast
* better error handling (G_unopen_cell)
r3.out.vtk
* added new flag "-o" -- the scalefactor effects the origin
r.out.vtk
* documentation update
* added new flag "-p" -- pointdata support if no elevation map is given
* added new option -- elevation value for 2D data
New module:
r3.in.rast
* converts 2d raster maps into one G3D map
* the number of 2D maps can be less than the depths of the G3D region, the
   last 2D map is used to fill the G3D raster
This module works only if the G3D resolution is equal to the current window resolution.
Thats all for the moment.
I want to implement a new module which produces cross-section 2D maps from a G3D map by a given 2D elevation map.
All modules and diffs (for CVS) are available at:
http://www-pool.math.tu-berlin.de/~soeren/grass/modules/
Because i have no CVS write access, it would be nice if somebody with write access can add the changes to the cvs. The needed diff's are available at my homepage (the link above).
It would be great too,
if somebody can test these modules, because i have only 2 test datasets. The modules are working fine at my machine (Fedora Core 3 Linux 32bit kernel 2.6.12, AMD 3000+ 512Mb RAM, grass6.1-cvs), but please use only testdatasets to prevent damage on your data, because im not able to emulate all errors which i try to handle ... .
Feel free to send me any comments, hints and critism about the modules.
Best regards
Soeren Gebbert
I just tested r3.out.rast and r3.in.rast (we would like to use it to store time series output from simwe).
It seems to work well, but r3.in.rast is not in the current CVS - is anybody planning to add it? I can do it if there is nobody who can do it faster than me. I got it from here:
Soeren, thank you very much for this - it should make managing numerous sets of time series much easier,
Helena
Soeren Gebbert wrote:
Updates:
g.mremove
r3.to.rast
r3.out.vtk
r.out.vtk
New module:
r3.in.rast
Best regards
Soeren Gebbert
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Helena,
I put menu items for these modules in the current GIS Manager with the hope
that they'd be out soon. I might need to double check the module name in the
menu, however.
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
Date: Wed, 28 Sep 2005 14:17:29 -0400
To: Soeren Gebbert <soeren@pool.math.TU-Berlin.DE>
Cc: <grass5@grass.itc.it>
Subject: Re: [GRASS5] some new r3.* modules and updates in grass6.1-cvs
Helena
Updates:
g.mremove
r3.to.rast
r3.out.vtk
r.out.vtk
New module:
r3.in.rast
window resolution.
Best regards
Soeren Gebbert
grass5 mailing list
grass5@grass.itc.it
I submitted it a day or two ago, please check it out - it would be useful to test it a little more. I hope I did it correctly.
Helena
Michael Barton wrote:
Helena,
menu, however.
Michael
phone: 480-965-6213
fax: 480-965-7671
Helena
Updates:
g.mremove
r3.to.rast
r3.out.vtk
r.out.vtk
New module:
r3.in.rast
window resolution.
Best regards
Soeren Gebbert
grass5 mailing list
grass5@grass.itc.it
