[GRASS5] Some strange HTML online output
while looking at the HTML man pages:
http://grass.itc.it/gdp/html_grass5/html/p.map.html
http://grass.itc.it/gdp/html_grass5/html/p.map.new.html
some strange output occurs:
Menu for /gdp/html_grass5/html/p.map.html
          html
[an internal server error occured]
Obviously these pages are treated as something different
(PHP?).
Any ideas to solve this? The HTML code is o.k., I think.
On Thu, Jan 24, 2002 at 01:11:32PM +0100, Markus Neteler wrote:
          html
(PHP?).
Check the log file(s) of the server for messages.
You might need to turn on debugging information for this.
It most certainly is a configuration problem of the webserver
Professional Service for Free Software (intevation.net)
The FreeGIS Project (freegis.org)
FSF Europe (fsfeurope.org)
> Hi,
> html
> (PHP?).
Looking into error_log:
[Thu Jan 24 14:07:45 2002] [error] [client 140.XXX] map file
/gdp/html_grass5/html/p.map.new.html, line 2 syntax error: requires at least
two fields
-> map file?
Or course
http://grass.itc.it/gdp/html_grass5/html/ps.map.html
is also not readable.
The "map" in the filename confuses the Apache. But why (sorry,
yes, I could browse the web)?
          html
(PHP?).
It doesn't matter whether or not the HTML code is OK. Even if you give
a ".html" extension to a file of completely random binary data, it
shouldn't cause an internal server error.
My suspicion is that the server has been configured to treat any
filename which contains[1] the string ".map" as a server-side image
map.
[1] as opposed to ending in ".map".
> html
> (PHP?).
map.
Thanks for the pointer. Looking into the config (not done by me) I
found:
grep map httpd.conf
LoadModule imap_module modules/mod_imap.so
AddModule mod_imap.c
Alias /tmp/ "/tmp/mapserver/"
<Directory "/tmp/mapserver/">
# AddHandler: allows you to map certain file extensions to "handlers",
# If you wish to use server-parsed imagemap files, use
AddHandler imap-file map
So the latter is suspicious. Next question is if I should
switch that handler off as we have the GRASS "mirrors" map:
http://grass.itc.it/index.html
On the apache docs I read "This module provides for server-side imagemap
processing."
I assume that this has nothing to do with our map, right?
Switching "AddHandler imap-file map" off should be fine?
Sorry for the naive questions,
> html
> (PHP?).
map.
Yes and no.
Yes: the server treats p.map.html as in imagemap (mod_imap).
No: you don't actually have to do anything special to get this
behaviour. I have exactly the same problem here, with a default Apache
1.3.14 setup.
The Apache documentation mentions the problem:
  http://httpd.apache.org/docs/mod/mod_mime.html#multipleext
I found that adding:
  AddHandler default-handler .html
to httpd.conf solves the problem, although it *might* interfere with
other uses of multiple extensions, e.g. as multi-language support (I
don't have anything like this here to test with).
> map.
found:
grep map httpd.conf
Yes, I've confirmed that as the cause.
processing."
Right. That map is client-side.
Yes. Assuming that you don't have any ".map" files, there isn't much
point in enabling it.
The same applies to any other AddHandler directives, although the only
ones enabled by default are "map" and "shtml", and I doubt that any
filenames will "accidently" contain ".shtml".
> > html
> > (PHP?).
> map.
Yes and no.
1.3.14 setup.
  mod_mime - Apache HTTP Server Version 2.4
Glynn,
perfect solution:
Thanks for the quick help to you and the others.
Multi-language support is not yet implemented (hi, volunteers).
