[GRASS5] SOurce code and clustering
Hi! I am a student studying GRASS in Korea.
I would like to know the total number of lines of the source code.
Also, I would like to know if clustering for parallel processing is possible.
You’re help would be greatly appreciated!
Thanks!
Jerry
last year I counted around 1.1 Million Lines of C. Now
it should be a bit more.
No idea, I have only one CPU...
Markus Neteler
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
subject 'unsubscribe grass5'
length: 1114
max: 0
Ok, I started a batch job to count this in 4.3 and 5.0.
Sure is bogging the server down. :wink: I'll let you know
Monday morning.
Bruce
Markus Neteler
length: 1114
max: 0
length: 1882
max: 0
On Sat, 15 Apr 2000, Bruce Byars wrote:
Ok, I started a batch job to count this in 4.3 and 5.0. Sure is bogging
the server down. :wink: I'll let you know Monday morning.
  I don't know off-hand what's required to make the code run as threads on
multiple processors. However, one of the premier compiler developers for
high-performance C and FORTRAN is located here in Portland: The Portland
Group. Since I know their sales manager -- and I know that their products
are used very heavily here in the Silicon Forest, I'll inquire.
  I'm thinking of a beowulf cluster for running big GRASS models, so this is
of interest to me, too.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
              Making environmentally-responsible mining happen. (SM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
length: 1973
max: 0
Thank you so much for your reply. I will be looking forward to hearing from you.
Best,
Jerry
----- Original Message -----
To: <grass5@geog.uni-hannover.de>
Sent: Sunday, April 16, 2000 12:57 PM
Subject: Re: [GRASS5] SOurce code and clustering
Rich
length: 1973
max: 0
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ!ü¨»§¶Ú.žË›±Êâmçë¢a‘$ƒz÷¥¢™žžÔÞjh§µêçjYšŠX§‚X¬·
âµëhþh§¢·hšàzˆÿºxÿ…©ç¢÷«ý×°ŠØl¹¸ÞrßîžË›±Êâmè+jË9þW§‚Øÿß}¼™¬ÿ
Thank you so much for your reply. If you have any more info, please get back to me.
Best,
Jerry
Sent: Sunday, April 16, 2000 11:29 AM
Monday morning.
Bruce
> Hi,
> Markus Neteler
> length: 1114
> max: 0
length: 1882
max: 0
âµëhþh§¢·hšàzˆÿºxÿ…©ç¢÷«ý×°ŠØl¹¸ÞrßîžË›±Êâmè+jË9þW§‚Øÿß]|™¬ÿ
Thanks! I hope you got my last reply.
Jerry
From: "Markus Neteler" <neteler@geog.uni-hannover.de>
Sent: Saturday, April 15, 2000 6:04 PM
Markus Neteler
length: 1114
max: 0
âµëhþh§¢·hšàzˆÿºxÿ…©ç¢÷«ý×°ŠØl¹¸ÞrßîžË›±Êâmè+jË9þW§‚Øÿۍ:™¬ÿ
GRASS is quite modular, but it is not designed to be run
on more than one processor as far as I know.
It would make sense for some modules to utilise more than one
process, but this is not completly trivial to do.
  Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
On Mon, 17 Apr 2000, Bernhard Reiter wrote:
It would make sense for some modules to utilise more than one process, but
Bernhard,
  Local resources include the Oregon Graduate Institute (a private graduate
school in the middle of the Silicon Forest here) and The Portland Group (a
high-performace compiler developer), as well as interested individuals in
the local linux community. This is something I want to investigate because I
believe that it could be very useful in many simulation or modeling
situations.
Rich
length: 1923
max: 0
Bernhard,
situations.
Rich
as far as i remember a group from the university of heidelberg
investigated/evaluated this for grass4.x. But the link to the homepage
no longer exists (or i could'nt find it again). See the documentation in
grass4.3/src.alpha/doc_modules_heidelberg (in german!).
If i remember correct they found that it is not possible to run grass on
a multiprocessor system or cluster with reasonable effort. I have no
experience with that, but i think that it is very complicated as the
grass libraries have not been developed with this in mind. Think of map
calculations for raster maps: for some calculations you need the value
for the nth row to calculate the nth+1 row, which will produce
problems/overhead in a distributed enviroment.
I fear that even a multi-processor machine will spent most time waiting
for input/output or memory operations to complete, so that a faster bus
system (e. g. crossbar-architecture in SGIs big irons) will give better
performance than more CPUs.
Only some thoughts,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de, A.C.Lange@GMX.net
length: 3109
max: 0
