Hi
When I tried to deal with the spaces in a file name by replacing them with
"\ " I got an error:
GRASS:~ > v.in.shape -d input=~/esri_vect_utm/B_Major\ Cities\ 2.shp
output=miasta
WARNING: Log file not specified. Sending messages to 'standard error'
ERROR: ~/esri_vect_utm/B_Major Cities 2.shp - DBF not found, or wrong
format.
The "B_Major Cities 2.dbf" was there in the same directory as the "B_Major
Cities 2.shp". After removing spaces in corresponding files all was ok.
Could I handle the spaces some other way or is renaming files the only
solution?
Maciek
output=miasta
format.
solution?
The shell doesn't expand the tilde in that context; use $HOME instead,
i.e.:
v.in.shape -d input=$HOME/esri_vect_utm/B_Major\ Cities\ 2.shp
FWIW, ash and zsh don't expand the tilde even when the filename
doesn't contain spaces.
