Radim and Markus,
This is a request for a bit of fine tuning on the database modules. But I
also want to see what everyone thinks about it as it wouldn't do to make
things more difficult.
V.in.db and other database modules have a common format for specifying
attribute tables--which is a very helpful thing. There are two fields to
identify which table to use for attributes: one is called "database" and the
other is called "table". In some cases, the "database" field is a
host/database specification string (as in mysql). In other cases it is
simply a path to a table location (as in ASCII or dbf tables). I'd like to
suggest that the descriptive text that appears in the autogenerated GUI be
called "specify database or path to data table". This will make it easier
for new users (and forgetful old users like me) to know what to put in this
field.
A browse button would be nice here too, though only useful for those cases
where database is a path.
Thanks
Michael
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
Michael Barton wrote:
Radim and Markus,
field.
Thanks
Michael
OK, note that you can use 'label' (name/short description) and 'description' (long description), so something like
database_opt ->label = "Database";
database_opt ->description = "For dbf driver the path to the directory..."
Radim
Radim and Markus,
field.
Thanks
Michael
Radim
Better to add a new standard options to gislib, because both driver and database are reused in many modules. Look at G_define_standard_option()
in lib/gis/parser.c, there is already G_OPT_WHERE.
You have to define also new STD_OPT in include/gis.h, (G_OPT_DRIVER, G_OPT_DATABASE)
Then in modules use just:
driver_opt = G_define_standard_option(G_OPT_DRIVER);
database_opt = G_define_standard_option(G_OPT_DATABASE);
Radim
This makes good sense.
Michael
On 1/24/05 2:54 AM, "Radim Blazek" <blazek@itc.it> wrote:
Radim and Markus,
and the
like to
GUI be
this
field.
cases
Thanks
Michael
Radim
G_OPT_DATABASE)
Radim
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
