Hello all
I just did an update and compile of the release branch and received the
following error on an SGI using vendor compilers.
/usr/people/jhickey/grassRel/grass/src/ps.map/devices
mkdir OBJ.mips-sgi-irix6.5
make -f OBJ.mips-sgi-irix6.5/make.rules
if [ ! -d /.../grass/dist.mips-sgi-irix6.5/etc/paint ]; then mkdir
/.../grass/dist.mips-sgi-irix6.5/etc/paint; fi
if [ ! -d /.../grass/dist.mips-sgi-irix6.5/etc/paint/ps.devices ]; then
mkdir /.../grass/dist.mips-sgi-irix6.5/etc/paint/ps.devices; fi
cp ps.devices/* /.../grass/dist.mips-sgi-irix6.5/etc/paint/ps.devices
2>/dev/null ; true
*** Error code 2 (bu21)
*** Error code 1 (bu21)
GISGEN failure at STEP: src/ps.map
I'm not sure what is happening here. Any ideas?
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
subject 'unsubscribe grass5'
2>/dev/null ; true
Well, this looks like my fault again
The SGI "make" appears not to like the line:
cp ps.devices/* $(GISBASE)/etc/paint/ps.devices 2>/dev/null ; true
This was a "tar" command, but I changed it to "cp" so that it failed
to copy the "CVS" directory (which was causing "ps.select" to list
"CVS" as an option).
I'm not familiar with SGI's make, so I'm not sure what it is about
that line that it doesn't like.
The previous version was:
(cd ps.devices ; tar -cvf - * | (cd $(GISBASE)/etc/paint/ps.devices ; tar xvf - 2>/dev/null ); true )
Does enclosing the line in parentheses help?
Hi Glynn
Ahh. OK, I'll look into it. It should be easy to fix since I got
Makefile.in working a while ago.
I'm updating command.c so I'll let you know soon regarding that one.
Lets cross our fingers!
Sincerely,
Bangkok, Thailand
Hi Glynn
This is fixed now. The problem was that I use tcsh which does not
recognize 2 as a file descriptor so I changed the line to
${SHELL} -c "cp ps.devices/* $(GISBASE)/etc/paint/ps.devices 2>/dev/null
; true"
and all seems to work.
Sincerely,
Bangkok, Thailand
