Is there any particular reason there has been a recent move from using
strn*() function to using str*() functions?
Specifying the string length has security benefits.
Thanks!
Brad Douglas <rez@touchofmadness.com>
Thanks!
Hello Brad
It was a bugfix: with strncmp it was returning a match if one string was shorter than the other but matched the first n characters. We needed to match the whole string.
What is the problem with using strcmp specifically?
I had a think about it and couldn't think of any reason not to use strcmp(), so I changed some occurences of strncmp() I had added in the past (blindly following the way it was done in other parts of the proj library).
Paul
Paul,
> strn*() function to using str*() functions?It was a bugfix: with strncmp it was returning a match if one string was
Is this a comparison of two strings of arbitrary length or is the source
string known? Do you have an example of where it failed to work
properly? I'm curious.
Buffer overflow attacks.
I found a short article detailing the problem for anyone interested:
http://www.linuxsecurity.com/content/view/119087/49/
It isn't a huge deal, but it is something to be aware of.
match the whole string.Is this a comparison of two strings of arbitrary length or is the source
string known?
Well yes---we have a specific pre-determined keyword that we are trying to match against one read from a while. I presumed that after strcmp got to the end of the shorter string it would stop matching, which removes the possibility of a buffer overflow. I haven't found any information on this possiblity, and the man page for strcmp doesn't mention it.
It was discussed on the list two days ago:
http://grass.itc.it/pipermail/grass5/2005-August/019378.html
following the way it was done in other parts of the proj library).I found a short article detailing the problem for anyone interested:
The article seems to deal with comparing two user-supplied strings. So I don't think it's relevant. Also there is only a passing reference to strcmp /
strncmp and it doesn't explain what the issue with it is. As far as I understand it comparing two strings can't cause a buffer overflow in itself; the damage has to be done at the stage where the strings are read into memory?
There's been a lot of work done in GRASS in the
last few years to reduce the chances of buffer overflows (G_asprintf() etc.) although many unsafe assignments/comparisons still remain. I'd like to think I'm not adding any new ones though
Paul
> What is the problem with using strcmp specifically?Buffer overflow attacks.
I think you're getting confused with strcpy/strncpy. strcmp only reads
the strings, it doesn't write anything so it can't cause a buffer
overflow.
> Buffer overflow attacks.I think you're getting confused with strcpy/strncpy. strcmp only reads
overflow.
You are correct. Thank you for the reminder.
