[GRASS5] strange things on cmd line
today I found something unusual (maybe my error?):
GRASS:~ > s.surf.rst in=elev30.sites elev=elev.15m ten=30 smooth=1.0
slope=slope.15m aspect=aspect.15m
100%
Percent complete: history initiated
GRASS:~ > g.list rast map=user1
raster files available in mapset user1:
aspect.15m elev.15m flowacc.30m lsfactor.30m slope.30m
aspect.30m flowacc.15m gs13.clump slope.15m
But:
g.remove aspect.15m,slope.15m
s.surf.rst in=elev30.sites elev=elev.15m ten=30 smooth=1.0\
GRASS:~ >g.list rast map=user1
aspect.30m flowacc.15m gs13.clump slope.30m
Oops. The slope=slope.15m and aspect=aspect.15m are ignored!!
I had the experience, that breaking long lines as done above
is o.k. in GRASS.
Clueless,
On Wednesday 06 February 2002 15:31, Markus Neteler wrote:
Command line continuation (are not) should be determined by your shell, not
by GRASS. If it is a problem, then would it be GRASS's problem or a problem
with the shell?
Roger Miller
> Hi,
with the shell?
I have been using "\" successfully with other commands in GRASS (in bash).
Only s.surf.rst fails. Probably a parsing problem in that module?
> > Hi,
> shell, not by GRASS. If it is a problem, then would it be
> GRASS's problem or a problem with the shell?
If shell continuation works, the program will see exactly the same
as with a long line. Make sure you do not have anything on the line
after the backslash.
There might be a problem with parsing spaces and tabs in the module
if the above does not solve the problem.
For illustration see the following tests:
$ echo $BASH_VERSION
2.03.0(1)-release
$ echo bla bla bla | od -tcx
0000000 b l a b l a b l a \n
        20616c62 20616c62 0a616c62
0000014
bernhard@abnoba:~$ echo bla bla\
bla | od -tcx
0000014
bernhard@abnoba:~$ echo bla bla \
bla | od -tcx
0000014
  Bernhard
Professional Service for Free Software (intevation.net)
The FreeGIS Project (freegis.org)
FSF Europe (fsfeurope.org)
Thanks to all who helped with my s.surf.rst problem.
I fact there was a "blank" after \, now it's running well.
> > > Hi,
2.03.0(1)-release
0000014
> bla | od -tcx
0000014
> bla | od -tcx
0000014
  Bernhard
