[GRASS5] strange v.buffer behavior
We are having problems with v.buffer in GRASS 6.0 and 6.1. To document this, we tried it on the Spearfish data set. Here is what is happening.
Use v.buffer on the roads.
No problem. It behaves as expected.
Convert raster streams to vector (r.thin, r.to.vect)
New stream vector displays fine
Use v.buffer on converted stream vector.
Vector area created with 0 nodes, 0 lines, 0 areas, etc.
That is, v.buffer goes through the motions, does NOT generate an error, produces the vector folder and creates all the requisite vector files, but there is NOTHING in them (the coor file is 0kb and the rest are 4 kb—i.e., headers only)
Any idea what is going on?
Michael
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
there is NOTHING in them (the coor file is 0kb and the rest are 4 kb‹i.e.,
headers only)
I have tried: doesn't work
    r.thin streams out=streams2
    r.to.vect streams2 out=streams2 f=line
    v.buffer streams2 out=streams2_buf buf=100
Because (?):
    v.category streams2 op=report
    -> no categories
    v.db.connect -p streams2
    Database connection for map <streams2> is not defined in DB file
I assume that v.buffer only works if categories are present.
This indicates that something is missing in r.to.vect.
Analysing the code lines_io.c of r.to.vect shows that there is no
db_*() support implemented. I darkly remember that this is
missing due to the problem that you cannot easily assign
raster values to a line (if you don't want to make each line
as long as a single pixel).
Oh, RTFM:
Attributes are ignored for feature=line
http://grass.itc.it/grass60/manuals/html60_user/r.to.vect.html
So, once we have an algorithm to decide how to assign attributes
to lines within r.to.vect, then v.buffer will work (it should
print an error, though).
For now v.category will help to assign new categories:
v.category streams2 out=streams3 option=add
v.buffer streams3 out=streams3_buf buf=100
d.vect streams3_buf
Voila'!
Thanks Markus.
This all makes sense now--or at least I understand why v.buffer is not
working as expected. I apparently misunderstood r.to.vect, thinking that if
you did NOT specify a new cat value, it would assign the cat value of the
raster pixels to the vector created. (It DOES do this with areas doesn't
it?). It seems to me at least that this SHOULD be the default, although a
warning should be issued--or even the program should fail--if the number of
different vectors created approaches the number of pixels for lines or
areas.
At least knowing what is happening, we can work around it as you suggest.
Still, it would be nice if we could assign the raster cat to the vector in
many cases.
Michael
______________________________
USA
Date: Thu, 14 Apr 2005 14:21:26 +0200
To: Michael Barton <michael.barton@asu.edu>
Cc: grass5 <grass5@grass.itc.it>
Subject: Re: [GRASS5] strange v.buffer behavior
headers only)
Because (?):
    -> no categories
Oh, RTFM:
d.vect streams3_buf
Voila'!
