[GRASS5] Swig interface for Grass
I have uploaded the SWIG/PERL interface from
Ari Jolma to 6.1-CVS at
swig/perl/
The idea is to make GRASS *modules* accessible from
outside.
I would like to receive assistance for the following
(small) problems:
- the file swig/perl/Makefile.PL contains the path to GRASS source
  code hardcoded
- if GRASS was configured with --with-nls, the glocale.h isn't
  found
Unfortunately I am not familiar with PERL Makefiles, so
please someone may fix this in CVS.
As example the 'r.slope.aspect' module is implemented.
The GRASS libs have to be present in /usr/[local/]lib/ such
as for the GRASS-GDAL-ORG plugin.
Thanks to Ari for his efforts! I hope that this interface
will be extended by GRASS developers...
PS: see also this thread:
http://grass.itc.it/pipermail/grass5/2005-August/thread.html#19435
I have added draft 'doxygen' style documentation of the
new SWIG interface in CVS (swig/index.dox).
For a version in HTML, see here:
http://mpa.itc.it/markus/grass61progman/swig/GRASS_SWIG_interface.html
SWIG may help to use GRASS as GIS backbone in other applications,
be local, be WebGIS.
Does it indicates that adding python binding to grass
will be more easy? I like it!.
I can try to implement that (I am already using a small
python binding for grass library which includes only
few functions which are needed for me). If you are
already working for the python-binding,
count me for testing.
Grass must cross all boundaries... Languages, Toolkits,
platforms....all
On 11/23/05, Markus Neteler <neteler@itc.it> wrote:
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Change the rules, or the rules will change you
     ---------Kumaranasan
Yes, I guess so.
As far as I know nobody is working on it at the moment. So you are welcome!
platforms....all
Absolutely!
Hello all,
I was going through the perl-grass interface(swing)
and to do the same for python.
Since I am not good in "make and perl" I find difficulty in
modifying the Makefile needed.
So here I am attaching my "typemaps" for python-grass.
Can someone suggest how to develop the Makefile for this?
(attachments)
my_typemaps.i (1.34 KB)
renames.i (21 Bytes)
Hello Sajith,
sorry for the delay.
Unfortunately I don't know much about SWIG. My suggestion
is to study how things are done in GDAL. I can see that there
are all typemaps in
gdal/swig/include/
Maybe we should try the same?
Probably I should launch a "call for help" in the
FreeGIS mailing list to find someone to help?
On Sun, Dec 25, 2005 at 12:43:32PM +0530, Sajith VK wrote:
Hello all,
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
hallo,
what I have read on wikipedia (http://en.wikipedia.org/wiki/SWIG), SWIG
is released under a BSD type license. Could that not be a problem for
GRASS at least for distribution of both software in one package?
I tryed to compile and use the grass.pm module, without success:
./configure --with-cxx --with-nls --with-freetype --enable-largefile --with-tcltk-includes=/usr/include/tcl8.3 --with-postgres-includes=/usr/include/postgresql/ --with-freetype-includes=/usr/include/freetype2/ --with-fftw --with-nls --with-readline --with-sqlite
cd swig/perl
perl Makefile.PL
MakeMaker (v6.17)
Writing Makefile for R_slope_aspect::r_slope_aspect
Writing Makefile for Grass
make
make[1]: Entering directory `/usr/src/gis/grass/grass6/swig/perl/R_slope_aspect'
cd r_slope_aspect && make LIB="" LIBPERL_A="libperl.a" LINKTYPE="dynamic" PREFIX="/usr" OPTIMIZE="-O2" PASTHRU_DEFINE="" PASTHRU_INC=""
make[2]: Entering directory `/usr/src/gis/grass/grass6/swig/perl/R_slope_aspect/r_slope_aspect'
cc -c -I/usr/include -I/usr/src/gis/grass/grass6/include -D_REENTRANT -D_GNU_SOURCE -DTHREADS_HAVE_PIDS -DDEBIAN -fno-strict-aliasing -pipe -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -DVERSION=\"\" -DXS_VERSION=\"\" -fPIC "-I/usr/lib/perl/5.8/CORE" -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -Wall -fpic -ggdb -DPACKAGE=\""grassmods"\" r_slope_aspect.c
r_slope_aspect.c:4:23: error: grass/gis.h: No such file or directory
In file included from r_slope_aspect.c:5:
local_proto.h:2: error: syntax error before 'RASTER_MAP_TYPE'
r_slope_aspect.c:6:27: error: grass/glocale.h: No such file or directory
r_slope_aspect.c: In function 'r_slope_aspect':
r_slope_aspect.c:36: error: storage size of 'cats' isn't known
r_slope_aspect.c:49: error: 'DCELL' undeclared (first use in this function)
r_slope_aspect.c:49: error: (Each undeclared identifier is reported only once
r_slope_aspect.c:49: error: for each function it appears in.)
r_slope_aspect.c:49: error: 'elev_cell' undeclared (first use in this function)
r_slope_aspect.c:49: error: 'temp' undeclared (first use in this function)
I suppose, this has something to do with last changes in grass header
files(?)
jachym
On Mon, Jan 02, 2006 at 09:15:44AM +0100, Markus Neteler wrote:
Hello Sajith,
are all typemaps in
gdal/swig/include/
> Hello all,
grass5 mailing list
grass5@grass.itc.it
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/
OFFICE:
Department of Geoinformation Technologies
LDF MZLU v Brnì
Zemìdìlská 3
613 00 Brno
e-mail: xcepicky@node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
Jachym,
I have fixed the problem in CVS (the wrong include path was defined).
Jachym Cepicky wrote:
hallo,
./configure --with-cxx --with-nls --with-freetype --enable-largefile --with-tcltk-includes=/usr/include/tcl8.3 --with-postgres-includes=/uusr/include/postgresql/ --with-freetype-includes=/usr/include/freetype2/ --with-fftw --with-nls --with-readline --with-sqlite
cd swig/perl
perl Makefile.PL
MakeMaker (v6.17)
make
files(?)
jachym
