Is there a TAGS file for the GRASS source code anywhere? Does anyone use one?
There isn't one included in the source tree.
I'm not sure that a global TAGS file would be a good idea; it's better
to create files which are relevant to the code on which you are
working (i.e. for the module itself and the libraries which it uses).
I occasionally create TAGS files for relevant parts of the tree.
Yes,
please have a look here:
http://grass.itc.it/
-> CVS
-> CVS branches (top menu)
-> List of GRASS CVS branches
Is this what you were looking for?
Yes,
please have a look here:http://grass.itc.it/
-> CVS
-> List of GRASS CVS branchesIs this what you were looking for?
No. A TAGS file is a list of symbols (variables, functions) along with
the file and line number where they are defined. It is used by text
editors to implement a feature allowing the user to go to the place
where a given symbol is defined.
