Glynn Clements wrote:
> any objections for creating the source tarball of the release branch?
> If not, I'll do that tomorrow morning Italian/Central European time.
We should check whether any of the recent changes should be
incorporated into the release. A complete list of the differences
between the head and the release branch follows.
I've sync'd all of the following:
aclocal.m4
configure
configure.in
Fix to LOC_CHECK_LIBS
GLw checks
src/raster/r.what/
Increase NFILES
Fix potential compile error (trailing garbage)
src/display/devices/XDRIVER/XDRIVER24/Serve_Xevent.c
Fix bug in resize code
src.contrib/GMSL/NVIZ2.2/src/tkInt8.0p2.h
src.contrib/GMSL/NVIZ2.2/src/tkInt8.0.2.h
src.contrib/GMSL/NVIZ2.2/src/tkInt8.0.5.h
src.contrib/GMSL/NVIZ2.2/src/togl.c
Add tkInt8.0.5.h
html/html/d.extend.html
Change format of Huidae's email address
mk/Makefile.docs
Fix bug in generating manpages
I've also sync'd:
src/display/devices/windows
Use gmake5
Various fixes
However, I've just discovered that Mike reverted the Makefiles,
apparently due to a problem with the Gmakefiles. I'd like to see what
the issue is before progressing.
In light of comments from Markus and Eric, I'll also sync these:
html/html/m.in.e00.html
Document -t switch
Additional comments regarding raster (GRID) files
handheld/
Added
src/libes/gis/sites.c
src/libes/gis/readsites_xyz.c
Catch ERANGE
src/raster/r.tiff/
html/html/r.in.tiff.html
Eric's true-colour changes
I've also decided to sync:
src/raster/r.in.png/
html/html/r.in.png.html
My true-colour changes (and re-write)
The previous handling of true-colour images was extremely dubious; it
attempted to read user input, regardless of whether stdin was a tty,
and generated massive colour tables.
There's also the GLw changes to r3.showdspf.openGL/Gmakefile, which I
omitted to mention. I'll sync those; r3.showdspf.openGL isn't built by
default, so it isn't critical either way.
That leaves the following awaiting a decision:
src/display/d.text.freetype
html/html/d.text.freetype.html
html/display.html
html/grass_commandlist.html
html/html/d.text.html
Support "freetypecap" file
Add HTML file
Reference d.text.freetype from other files
d.text.freetype is fairly new anyway, so I don't see any point in
using an older version.
src/include/gisdefs.h
src/include/glocale.h
src/libes/gis/locale.c
src.garden/grass.postgresql/*/
documents/grass_i18n_howto.html
I18N update
The release branch has the last-but-one version of the I18N interface
(which is basically a historical accident; this just happened to be
the situation on the day the branch was made), so it should probably
be sync'd.
src/sites/s.surf.rst/
Resurrect I18N
I18N should be harmless (if you don't have libintl.h, it's a definite
no-op).
src.garden/grass.postgresql/v.to.pg/
html/html/v.to.pg.html
locale/ru/LC_MESSAGES/v.to.pg.po
PostGIS support ("-p" switch)
I don't know about this bit.
src.contrib/GMSL/NVIZ2.2/scripts/nviz2.2_script
src.contrib/GMSL/NVIZ2.2/src/nviz_init.c
Load state file ("state=") option
This bit doesn't look right:
--- /usr/src/grass5-rel/src.contrib/GMSL/NVIZ2.2/scripts/nviz2.2_script Tue Jan 22 04:51:40 2002
+++ /usr/src/grass5-head/src.contrib/GMSL/NVIZ2.2/scripts/nviz2.2_script Wed May 8 01:39:42 2002
@@ -320,7 +320,7 @@
appBusy
if {$fname != -1} then {
- Nwrite_ppm $fname
+ Nwrite_ppm $fname 1
# show user can proceed
appNotBusy
