Concerning this patch: Should it be applied to 5.0.3 or not?
If yes, I'll prepare a 5.0.3RC4, otherwise we should release
5.0.3RC3.
On Wed, Sep 17, 2003 at 10:11:09PM +1200, Hamish wrote:
Bug #2: (got it.)
In src/libes/ogsf/GS2.c's GS_load_att_map(), the 'mapset' variable is
used uninitialized if "reuse" is true.
Moving the 'mapset=xxxx;' bit out of the condition to about line 1257
just before 'if (reuse)' stops the segfault; see the attached patch.
Could someone please test & commit to CVS if it's good, as I'll be out
of town until next week & won't be able to.
Looks ok, but I'm not really sure how much "reuse" reuses.. no chance of
using the wrong mapset from a previous call is there? That would be a
very ugly bug to catch.
forwards in all directions,
Hamish
--- src/libes/ogsf/GS2.c.ORIG 2002-08-13 09:45:19.000000000 +1200
+++ src/libes/ogsf/GS2.c 2003-09-17 21:55:09.000000000 +1200
@@ -1254,6 +1254,9 @@
begin = 0;
+ /* Get MAPSET to ensure names are fully qualified */
+ mapset = G_find_cell2 (filename, "");
if (reuse)
gs->att[att].hdata = hdata;
@@ -1290,8 +1293,6 @@
tbuff = gs_get_att_typbuff(gs, att, 1);
- /* Get MAPSET to ensure names are fully qualified */
- mapset = G_find_cell2 (filename, "");
filename = G_fully_qualified_name(filename, mapset);
/* TODO: Provide mechanism for loading certain attributes at
Markus Neteler <neteler@itc.it> http://mpa.itc.it
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
