[GRASS5] tclsh and wish
Hi developers,
I suggest to use GRASS_TCLSH and GRASS_WISH env vars to use non-standard
names. It can be easily overrided by env vars and does not require hard-coded
name. If these env vars exist, scripts use this name, otherwise standard name.
If someone uses wish8.3 instead of wish, GRASS_WISH=wish8.3 can be used.
set env vars in grass5:
if [ ! "$GRASS_TCLSH" ]
then
    GRASS_TCLSH=tclsh
    export GRASS_TCLSH
fi
if [ ! "$GRASS_WISH" ]
then
    GRASS_WISH=wish
    export GRASS_WISH
fi
Now scripts can have only:
wish script:
#!/bin/sh
# the next line restarts using wish \
exec $GRASS_WISH "$0" "$@"
tclsh script:
#!/bin/sh
# the next line restarts using tclsh \
exec $GRASS_TCLSH "$0" "$@"
Any objections?
subject 'unsubscribe grass5'
