[GRASS5] Testing Grass 5.3 - v.transform
Radim
Just wanted to let you know. I tested v.transform by typing in the name of a binary vector file (the browse button looks in the dig_ascii instead of dig folder). It worked just fine. Thanks for the tip.
Michael
On Monday, January 19, 2004, at 01:54 AM, Radim Blazek wrote:
On Friday 16 January 2004 17:13, Michael Barton wrote:
As with GRASS 5.7, I've been doing considerable testing of GRASS 5.3.
Overall, it is highly stable and works very well. Here are a couple of
minor items that perhaps could be fixed before it is released as stable.
1. v.transform does not operate correctly, at least under Mac OSX. It
requires an ASCII vector file as input, looks in the dig_ASCII folder,
but will not recognize an ASCII vector file unless it is put (manually
and incorrectly) into the dig folder. It produces an incomplete output
file (header and attributes, but no vectors). This was a problem on an
earlier release; I have tried this on the the 12 January CVS snapshot
and it is still a problem.
v.transform was rewritten to read and write vector binary file.
Radim
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
On Wed, Jan 28, 2004 at 10:20:17PM -0700, Michael Barton wrote:
Radim
Michael,
this is not clear to me:
src/mapdev/v.transform/main.c
       old->gisprompt = "old,dig,vector";
The version in 5.3-CVS refers to the dig file.
Where did you find the reference to dig_ascii? Maybe in 5.0.3?
>>stable.
>Radim
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
