[GRASS5] The status of 5.0
Glynn wrote:
But I don't see how this helps scripts.
It doesn't, but apparently I haven't used any of the scripts that need
help. As you say, perhaps the best solution is to rewrite the scripts
to evaluate the output from g.gisenv.
For C programs, switching mapsets/locations should just be a matter
of
modifying the appropriate variable in $GISRC.
Yes you can do that if you want to; if you want to remember the settings
each time you change locations and if you only want to use one gis
environment at a time. I prefer to give the user easier access. The
manager allows users to maintain different gis environments associated
with different monitors at the same time and to switch back and forth
between them, to add new ones and to remove old ones. It also allows
users to display multiple geographic windows within each gis
environment.
I expect that as GRASS evolves it will be desirable to expand the number
of resources stored in $GISRC or elsewhere. In particular, I'd love to
see the default vector color and default screen background stored in
$GISRC. As the amount of information expands the task of switching
environments becomes more difficult.
Roger Miller
