Glynn,
can you implement this change so that it gets into the next release, if there are no objections?
I have always thought that 0 as NULL has been gone with GRASS4,
I find it pretty confusing (even in GRASS4* it has always caused all kinds of problems).
I work almost exclusively with FP maps so I did not realize
that this behavior is still there.thank you,
Helena
On Nov 23, 2005, at 12:54 PM, Glynn Clements wrote:
Joel Peter William Pitt wrote:
I need to store many thousands of maps for different model simulation
runs as each has at least 25 maps in a timeseries.Currently running 100 replications of a 25 year model on a 2000x2000
region results in about 2.1 gig.
This on its own is okay, but I need to run sensitivity analyses on a
range of parameters, meaning each value I test for a parameter gives a
location of 2.1 gig!Checking out the actual data files however shows that the cell files are
only about 60k each. The problem is the uncompressed null bitmasks that
are 700k each. Now, I can explicitly remove the null bitmask using
"r.null -r", but I was wondering if the null mask will just get
automatically created next time I run a GRASS command?The null file is created when the map is created, or via r.null.
Also, I'm under the impression that if there is no null bitmask then
values equal to 0 in the cell file are interpreted as nulls, is this
right?For integer maps, yes. If a FP map doesn't have a null bitmap, all
cells are valid.This is for compatibility with 4.3, which didn't have null bitmaps. It
didn't have FP maps either, so compatibility isn't an issue there.This behaviour could easily be removed; see the following code in
get_null_value_row_nomask() in lib/gis/get_row.c:if (read_null_bits(null_fd, fcb->null_work_buf,
i+fcb->min_null_row, fcb->cellhd.cols, fd) < 0)
if (fcb->map_type == CELL_TYPE)
If can't read null row, assume that all map 0's are nulls
use allocated G__.mask_buf to read map row */
get_map_row_nomask(fd, (void *) G__.mask_buf, i+fcb->min_null_row,
CELL_TYPE);
for (j = 0; j < G__.window.cols; j++)
if (G__.mask_buf[j] == 0)
flags[j] = 1;
else
flags[j] = 0;
else /* fp map */
/* if can't read null row, assume that all data is valid */
G_zero(flags, sizeof(char) * G__.window.cols);
/* the flags row is ready now */
} /*if no null file */To disable the behaviour, replace the above block with:
} /*if no null file */4.3 is old enough that we could probably just remove that behaviour
altogether. It just requires anyone using maps which were created
using 4.3 to add a null bitmap with r.null.Is there anyway to specify NOT creating a null mask when creating a
map?No.
Glynn Clements <glynn@gclements.plus.com>_______________________________________________
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5Helena Mitasova
Dept. of Marine, Earth and Atm. Sciences
1125 Jordan Hall, NCSU Box 8208,
Raleigh NC 27695
http://skagit.meas.ncsu.edu/~helena/
Helena Mitasova
Raleigh NC 27695
