Grass list,
I checked out the code yesterday (not an update, a cvs co)
and it failed because it could not change directory into a TODO
directory. In Unix we can have upper and lower case
distinctions, not so in Cygwin. Would somebody please
check to see if there is a "todo" directory, if so, remove
the todo file?
Thanks much,
John Huddleston, P.E.
PhD Student
Colorado State University
subject 'unsubscribe grass5'
On Sun, Feb 04, 2001 at 06:14:55AM -0700, John Huddleston wrote:
Grass list,
the todo file?
Hi John,
yes, I can see the problem (bad Windows!). So I will rename
todo/ to src.todo.
Sorry for this inconvenience,
> Grass list,
> the todo file?
Hi John,
todo/ to src.todo.
John,
it's done.
cvs up -dP todo src.todo
Thanks for notification,
Grass list,
the todo file?
Is this lack of case sensitivity just in the make environment? I've
been using CygWin a little at work, and it seems to respect case (maybe
it's different on NTFS vs. the various FAT filesystems?).
Eric G. Miller <egm2@jps.net>
