[GRASS5] Todo
On Sunday, February 4, 2001, at 11:27 AM, Eric G . Miller wrote:
> I checked out the code yesterday (not an update, a cvs co)
> and it failed because it could not change directory into a TODO
> directory. In Unix we can have upper and lower case
> distinctions, not so in Cygwin. Would somebody please
> check to see if there is a "todo" directory, if so, remove
> the todo file?
Is this lack of case sensitivity just in the make environment? I've
been using CygWin a little at work, and it seems to respect case (maybe
it's different on NTFS vs. the various FAT filesystems?).
Greetings,
I just got this TODO, too here in Mac OS X land.
  > cvs -z3 co -r "release_grass5beta11_4_february_2001" grass
snip...
unrecognized request `TODO/'
I don't know what's case-sensitive and until the recent INSTALL problem I was not aware of it's case-sensitivity.
My grass directory does indeed have a todo directory. Should I move it? It has a display_driver directory in it.
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
> > the todo file?
Greetings,
snip...
Hi Jeshua,
you are currently not using "cvs update" but "cvs checkout".
You will
- either "cvs up -dP" the current cvs tree
- or "cvs -z3 co -r "release_grass5beta11_4_february_2001" grass" a new
   grass sources tree into an *empty* directory.
A mixture will cause above problems.
Currently
cvs up -dP todo
cvs up -dP
in your existing tree will do the job as so far no new
changes are uploaded.
Hope this helps,
