[GRASS5] Tools for importing data from mapping servers
Good day,
I've written a new script for easing importing of tiled data from another
projection. It accepts a list of input files that gdalwarp can handle, as
well as a gdalwarp s_srs source projection and produces a single map in the
current database.
http://www.shockfamily.net/cedric/grass/r.in.gdalwarp
Usage example:
input=$HOME/Desktop/RedTile1.geotiff,$HOME/Desktop/RedTile2.geotiff,
$HOME/Desktop/RedTile3.geotiff output=RedTileset s_srs=EPSG:4326
Details: it projects the data in with gdalwarp, asking for a geotiff file with
alpha channel and nodata values marked in the alpha channel. It uses mapcalc
to mark nulls in the other channels where alpha is exactly 0. Finally it
patches all the various inputs together and cleans up the temporary maps.
Issues: Doesn't write history. Anyone want to tell me the right way to do
this?
Additionally I have made small changes to r.tileset, including an overlap
option to add extra cells to the right and top sides of the tiles:
http://www.shockfamily.net/cedric/grass/r.tileset
--Cedric Shock
do this?
r.patch will write it's history (command line), but from a shell script
there isn't a good way (yet). Writing a line to the history should be a
command line option of r.support, but isn't yet.
Hamish
> do this?
For myself, I have simply added text to the hist file,
something like this
meta="metadata bla bla bla"
HISTFILE=$LOCATION/hist/$RASTERMAP
#determine total length:
STRINGLENGTH=`echo $meta | wc -c | awk '{printf $1}'`
#maximal allowed string length for GRASS hist file 62 chars:
#(max 20 lines accepted, rest silently truncated by GRASS modules)
LINELENGTH=62
#insert linebreaks, if needed
i=1
while [ $i -le $STRINGLENGTH ]
do
NEXT=`expr $i + $LINELENGTH`
echo $meta | cut -b$i-$NEXT >> $HISTFILE
i=`expr $i + $LINELENGTH`
i=`expr $i + 1` # need one more
done
Of course it's highly desired to get this added to r.support.
LINELENGTH=62
gis.h:
#define MAXEDLINES 50
#define RECORD_LEN 80
struct History
    char mapid[RECORD_LEN];
    char title[RECORD_LEN];
    char mapset[RECORD_LEN];
    char creator[RECORD_LEN];
    char maptype[RECORD_LEN];
    char datsrc_1[RECORD_LEN];
    char datsrc_2[RECORD_LEN];
    char keywrd[RECORD_LEN];
    int edlinecnt;
    char edhist[MAXEDLINES][RECORD_LEN];
so 50 rows x 80 cols.
62 may be the limit that r.info will show? 'r.info -h' should show all.
In G_command_history() I used 70. Seems ok.
yes.
Hamish
> LINELENGTH=62
gis.h:
struct History
    int edlinecnt;
Ah, I forgot to mention that I wrote the script a few years
ago.
yes.
I will do sit and wait strategy :slight_smile:
