From: Markus Neteler <neteler@geog.uni-hannover.de>
while defining a new location (a large one) I got:
total rows: 58400
total cols: 65600
total cells: -,463,927,296total cells should be 3831040000
How can I fix this? Brain overload?
Yours
Well, if you have only printout problem, there is a way to fix that.
By the way, I don't know why `unsigned int' doesn't work at all.
`unsigned int' and 'signed int' work same way, the same range.
`unsigned int' accepts negative integer value too :-(.
Best Regards,
Huidae Cho
subject 'unsubscribe grass5'
