[GRASS5] trouble copiling 5.1
I have trouble compiling 5.1. It fails with
make[2]: Entering directory `/home/mlennert/SRC/grass51/vector/v.digit'
gcc -g -Wall -I/home/mlennert/SRC/grass51/include -I/home/mlennert/SRC/grass51/dist.i686-pc-linux-gnu/include -I/home/mlennert/SRC/grass51/include -I/home/mlennert/SRC/grass51/dist.i686-pc-linux-gnu/include -I/usr/X11R6/include/ -I/usr/include/gr -I/usr/local/include -I/usr/include -I/usr/include/postgresql -I/usr/include/postgresql/internal -I/home/mlennert/SRC/grass51/include -I/home/mlennert/SRC/grass51/dist.i686-pc-linux-gnu/include \
        -o OBJ.i686-pc-linux-gnu/c_face.o -c c_face.c
c_face.c:4: tcl.h: No such file or directory
c_face.c:5: tk.h: No such file or directory
In file included from c_face.c:8:
global.h:1: tcl.h: No such file or directory
global.h:2: tk.h: No such file or directory
make[2]: *** [OBJ.i686-pc-linux-gnu/c_face.o] Error 1
make[2]: Leaving directory `/home/mlennert/SRC/grass51/vector/v.digit'
make[1]: *** [subdirs] Error 1
make[1]: Leaving directory `/home/mlennert/SRC/grass51/vector'
make: *** [default] Error 1
I use the config command:
CFLAGS="-g -Wall" ./configure --with-grass50=/home/mlennert/SRC/grass50 --with-tcltk-includes=/usr/include/tcl8.3 --with-postgres-includes="/usr/include/postgresql /usr/include/postgresql/internal"
and the configure seems to work well:
checking whether to use Tcl/Tk... yes
checking for location of Tcl/Tk includes... /usr/include/tcl8.3
checking for tcl.h... yes
checking for tk.h... yes
checking Tcl version... 8.3
checking Tk version... 8.3
checking for location of Tcl/Tk library...
checking for Tcl_Init in -ltcl... no
checking for Tcl_Init in -ltcl8.3... yes
checking for Tk_MainWindow in -ltk... no
checking for Tk_MainWindow in -ltk8.3... yes
Can someone help me ?
Moritz
It appears that vector/v.digit/Makefile needs:
  EXTRA_CFLAGS = $(TCLINCDIR) $(TKINCDIR)
Now I get:
make[2]: *** No rule to make target `settings.tcl', needed by `/home/mlennert/SRC/grass51/dist.i686-pc-linux-gnu/etc/v.digit/settings.tcl'. Stop.
I actually don't have a settings.tcl, nor the incons directory also mentioned in the Makefile. Is this a a problem in the vector/v.digit/Makefile, or am I missing files (cvs update does not get anything else) ?
Moritz
'. Stop.
anything else) ?
Sorry, I added EXTRA_CFLAGS to my Makefile and commited the Makefile
only and forgot that it is completely changed, no it is reverted to older
version + EXTRA_CFLAGS.
Radim
'. Stop.
anything else) ?
Radim
Now I get two more errors:
1) a simple typo (missing ;):
make[2]: Entering directory `/home/mlennert/SRC/grass51/vector/v.mapcalc'
gcc -O2 -Wall -Werror -rdynamic -o mapcalc.o -c mapcalc.c
bison -d v.mapcalc.y
gcc -O2 -Wall -Werror -rdynamic -o yylex.o -c yylex.c
gcc -O2 -Wall -Werror -rdynamic -o v.mapcalc.o -c v.mapcalc.tab.c
v.mapcalc.y: In function `yyparse':
v.mapcalc.y:72: parse error before `}
2) I don"t know how to fix this:
OBJ.i686-pc-linux-gnu/query_postgr.o(.text+0x17d): In function `query_postgr':
/home/mlennert/SRC/grass51/visualization/nviz/src/query_postgr.c:59: undefined reference to `runInfxQry'
OBJ.i686-pc-linux-gnu/query_postgr.o(.text+0x2c8): In function `query_pg_site':
/home/mlennert/SRC/grass51/visualization/nviz/src/query_postgr.c:102: undefined reference to `runqry'
collect2: ld returned 1 exit status
Moritz
v.mapcalc does almost nothing now, so I removed it from vector/Makefile.
`query_postgr':
`query_pg_site':
I don't know.
Radim
> `query_postgr':
> `query_pg_site':
I don't know.
runqry() is defined in runInfxQry.c; however, that file is only used
if the "doconfigure" script (visualization/nviz/doconfigure) sets it
up that way. Basically, there are two versions of query_postgr.c; a
version which actually uses Postgres (query_postgr_orig.c), and a stub
version (query_postgr_dummy.c). The doconfigure script copies one of
these to query_postgr.c. A similar situation exists for
panel_query.tcl.
Also, the whole of runInfxQry.c is conditionalised upon:
#if defined(HAVE_POSTGRES_H) || defined(HAVE_POSTGRES_FE_H)
Basically, the way in which NVIZ' Postgres support is handled is
something of a hack, and needs to be cleaned up.
We have 'pg' driver in grass51 now, so I think that Postgres in
nviz may be replaced by dbmi (code for vectors will be the
same as for d.what.vect -a)
Radim
is handled is
On CVS head:
VARHDRSZ if defined directly (not from postgres-fe.h);
I've finished removing "dirty-style" programming code
from
grass.postgresql which I rudely introduced there. Now
all 13
modules a) are uniform with QRY_LENGTH defined in
header
file instead of (1024) everywhere in code b)
PQclear added everywhere in error checks c) renamed
confusing -Infx- names to -Pg- d) removed unused
variables/header files. e)removed bogus static
definitions for SQL command buffers + identing and
minor changes. I also removed (or not? at least I
tried to!) confusing v.in.shape.pg_alex&david dirs (we
don't want them?), the same about oldman.
I commented out v.in.arc.pg in modules Gmakefile. (?)
I updated the manual "First steps" and Readme, too.
I will update the CVS on Pogtgres NVIZ support some
time later to get rid of the older hack.
--alex
__________________________________________________
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
http://mailplus.yahoo.com
