[GRASS5] trouble with r.in.bin size check
I received the following in one of the responses to the questionnaire.
Moritz
----- Forwarded message from Pedro Camilo Alcantara Concepcion <camilo@pcbiol.fciencias.unam.mx> -----
I have a bug report that i didn´t done because i didn't have time, i send
here...
Well i have some Landsat ETM+ 2000-2001 images, originaly rectified in PCI
and exporter to raw, PCI export the image with a header embeded. well the
problem is that: if i try to import with r.in.bin in the latest grass
version 5.0pre2 or pre3 this command check the size of the file an reject
the import, but if i use the r.in.bin of an old version the check routine
didn´t exist and i can import the image correctly. I suggest to create a
flag whith the option of check the size or resolve the problem in some
equivalent way.
Thank you for the development of free GNU software.
Best Regards
Camilo Alcántara
Instituto de Geografía
Departamento de Ordenamiento Territorial y Ecogeografia
Morelia, Michoacan, México
----- End forwarded message -----
Camilo,
could you provide a detailed error message generated from r.in.bin?
AFAIK the module's check routines runs well.
Thanks
Moritz
> here...
> equivalent way.
> Best Regards
> Camilo Alcántara
