[GRASS5] trouble with vector layers
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hello,
Don't know if this is a bug or if I just don't understand the use of
layers:
GRASS 6.1.cvs (BELGIQUE):~ > v.db.connect -p molenbeek
Vector map <molenbeek> is connected by:
layer <1> table <molenbeek> in database <grass> through driver <pg>
with key <cat>
layer <2> table <molpoptot> in database <grass> through driver <pg>
with key <cat>
the cat column is identical in the two tables. However:
GRASS 6.1.cvs (BELGIQUE):~ > d.vect molenbeek where='cat>8000'
displays the right areas, but
GRASS 6.1.cvs (BELGIQUE):~ > d.vect molenbeek layer=2 where='cat>8000'
does not display anything. At the same time
v.db.select molenbeek layer=2 where='cat>8000'
correctly lists the corresponding lines in the table molpoptot.
Moritz
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDKTUarIrMbm76jD8RAucEAJ9LTNlJWobyEg98Kc2xl0wZlWkbTACdG483
v0POBQi73maZ713WpBlB16s=
=FVva
-----END PGP SIGNATURE-----
Can you send output from:
v.category input=molenbeek option=report
Radim
Hash: SHA1
Hello,
layers:
with key <cat>
with key <cat>
Moritz
=FVva
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Hash: SHA1
GRASS 6.1.cvs (BELGIQUE):~ > v.category input=molenbeek option=report
LAYER/TABLE 1/molenbeek:
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 46 7596 8192
area 0 0 0
all 46 7596 8192
option=report layer=2
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
area 0 0 0
all 46 7596 8192
Doesn't seem to take into account layer 2...
The same goes for
GRASS 6.1.cvs (BELGIQUE):~ > v.category input=molenbeek option=print
layer=2
whereas
layer=1
prints out the category values.
Moritz
Radim
Hello,
layers:
with key <cat>
with key <cat>
Moritz
grass5 mailing list
grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
iD8DBQFDKZDCrIrMbm76jD8RAp6pAJ0YqpltVG7fwJ9kiPgAX76h2g/yggCeNHjz
jNgiwYVdA0amj1iptMgsayo=
=Qh7C
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
area 0 0 0
all 46 7596 8192
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
area 0 0 0
all 46 7596 8192
No, option=report prints all layers. There are no features in layer 2
in your map.
Radim
Hash: SHA1
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
area 0 0 0
all 46 7596 8192
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
area 0 0 0
all 46 7596 8192
in your map.
Ok, so it was a problem of me not understanding layers correctly.
Sorry...
Do I then understand correctly that you cannot link one layer to
different tables simultaneously ?
Moritz
iD8DBQFDKno4rIrMbm76jD8RAqwlAKCA+RoX0i9uqO5hRstdpZS7RjyTlgCfUSVp
WlUxGjE0gK0tgVRt2EJyaaY=
=yCe8
Hash: SHA1
Sorry...
Yes, you cannot.
Radim
