[GRASS5] Uh-oh: Beta11 problem
  Beta-11.2 installed just fine, but when I started it (just to be sure)
this is what I see:
Starting GRASS ...
/opt/grass5/etc/set_data: error in loading shared libraries:
libncurses.so.5: cannot open shared object file: No such file or directory
  Sure enough, I'm missing the library. Strange. I'll go see if I can find a
package that contains it.
  BTW, I modified grass5install.sh because I like to put applications such
as GRASS in /opt rather than /usr/local. Worked just fine -- at that point.
:slight_smile:
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
              Making environmentally-responsible mining happen. (SM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
subject 'unsubscribe grass5'
Hello Rich
such as GRASS in /opt rather than /usr/local. Worked just fine -- at
that point. :slight_smile:
Just to let you know, you shouldn't need to edit the grass5install.sh
script. The destination and binary directories can be specified on the
command line. Below I include the usage message for grass5install.sh
Usage: sh grass5install.sh grass_binpackage.tar.gz [dest_dir] [bin_dir]
  with:
    grass_binpackage : name of GRASS 5 binary package
    [dest_dir] - optional: FULL path name to the installation directory
            (default: /usr/local/grass5/)
    [bin_dir] - optional: FULL path name to the grass binary directory
            (default: /usr/local/bin/)
            Notes: 1) Only the grass executable file is stored here
                   2) If you want to change the binary directory only
                      then you need to specify the destination
                      directory as well
You may need login as root for installation.
Hope this is helpful on your next installation.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
