trying to reduce confusion (hopefully I didn't increase it),
I have updated
html/env_vars.html
The list is split now into a list of env vars and GRASS vars
So I hope that I got this right, otherwise please fix directly in CVS.
I have updated
html/env_vars.html
I have updated
html/env_vars.html
The list is split now into a list of env vars and GRASS varsSo I hope that I got this right, otherwise please fix directly in CVS.
How did you try to determine which is which? Because a brief glance
indicates that the method wasn't correct. E.g.
1. GRASS_GUI is listed as an environment variable, but is actually a
GRASS variable. Or, rather, it's meant to be a GRASS variable,
although it appears that setting it in the environment will override
any setting in $GISRC.
2. GISBASE and GISRC are listed as GRASS variables, but are actually
environment variables. GISRC absolutely has to be an environment
variable; given that it identifies the file which contains the values
of the GRASS variables, it cannot itself be a GRASS variable.
There are a few others that are definitely in the wrong category (but
for most of them, I wouldn't know which category was correct without
actually looking).
The most reliable way to check is to search the GRASS source tree
(with find/fgrep) for occurrences of the string "getenv". If the
variable name is passed to getenv(), it's an environment variable; if
it's passed to G_getenv() or G__getenv() it's a GRASS variable (except
for GISBASE, which is trapped by G__getenv()).
That leaves scripts. If a script uses e.g. `g.gisenv FOO`, then FOO is
a GRASS variable. If it just uses $FOO, and doesn't use g.gisenv, then
it's an environment variable. If it uses `eval g.gisenv`, shell
variables will obtain their value from $GISRC if it includes a setting
for that variable, and from the environment otherwise. A similar
principle applies to Tcl/Tk scripts, only the syntax is different.
> I have updated
> html/env_vars.html
> So I hope that I got this right, otherwise please fix directly in CVS.How did you try to determine which is which? Because a brief glance
So we are approximating a correct file (the former version wasn't better
in my opinion).
moved.
moved.
actually looking).The most reliable way to check is to search the GRASS source tree
for GISBASE, which is trapped by G__getenv()).That leaves scripts. If a script uses e.g. `g.gisenv FOO`, then FOO is
So any time someone comes across a bug in this file, he/she may feel
free to fix it. It's in CVS and writable:
html/env_vars.html
