mixed use of <em>,<i> and <strong>,<b> is rife in the help pages.
"What's the Difference?"
http://www.think-ink.net/html/bold.htm
comments?
Hamish
comments?
Hamish
Well, I'd say, given the uses in the description.html files, it should
neither be <b>/<i> nor <strong>/<em> in most cases.
We are using (indiscriminately) <b>,<i>,<em> to mark-up parameters or
command names, i.e. code, rather than using them for emphasis proper.
Visually, it's fine, but semantically it's awfully wrong.
A more correct way of handling this would be to use <span>s with a
semantically marked class, and expanding Markus' CSS to handle that,
visually. I.e. instead of "the <b>col</b> parameter" we should have
"the <span class="param">col</span> parameter". We might borrow
texinfo or docbook semantic classes for that.
Not really an automatic conversion, rather a long style correction
through every description file.
Daniel.
PS. Personally, I'd rather move all the docs from HTML to reStructuredText.
http://www.think-ink.net/html/bold.htmcomments?
Hamish
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
-- Daniel Calvelo Aros
