Markus,
In INSTALL under "UPDATE OF 5.7.x", it says:
In detail:
make mixclean
cd /where/your/grass50/lives/
cvs update -dP
cd /where/your/grass57/lives/
cvs update -dP
make mix
configure ...
make
Should this be:
cd /where/your/grass50/lives/ <- should this say 53?
cvs update -dP
make mixclean <- move to here, in 57
cvs update -dP
make mix
configure ...
make
It's not clear to me what directory you are in
when the directions start. I think this makes it
clear that "make mixclean" is done in 57 directory.
John
neteler
2
John,
On Fri, Sep 12, 2003 at 12:16:14PM -0400, John Gillette wrote:
Markus,
In detail:
make mixclean
cvs update -dP
cvs update -dP
make mix
configure ...
make
Should this be:
cvs update -dP
Generally yes.
However, top of the file there is a statement
Note: We use synonymical:
grass50 == grass50x == grass53x
unless the 50 references are all cleaned one day.
cvs update -dP
make mix
configure ...
make
Yes, thanks.
Right.
Updated in CVS, thanks,
