has anyone of you tried to use xcode to edit the grass code? i started using xcode for another project and i like it a lot. the problem is, whenever i add the folder containing the grass files to an empty xcode project, xcode simply dies after not even a minute of use without leaving a message in the crashlog.
any ideas?
cheers
florian
