Hi GRASS developers,
I have to compile a program that runs under grass using, among other things,
the 'vask' library. It compiles, but gives the following error when run:
GRASS:~ > swatgrass
'xterm-xfree86': unknown terminal type.
Error opening terminal: xterm-xfree86.
GRASS:~ >
I've determined that this message is generated when V_call() is called.
Curiously, when I run the program in gdb, it runs ok and the screen menus are
displayed just fine!
I thought maybe the problem has to do with how I linked in the termcap
library. Programmer's manual suggests using $(VASK), because "it specifies
both the UNIX curses and termcap libraries as well as $(VASKLIB)" (p. 286),
however, $(VASK) is not set when I ran 'gmake5' on the GMakefile (see below).
So I just plugged the libraries directly:
$(CC) $(LDFLAGS) -o $@ $(LIST) -ltermcap -lcurses $(LIBES)
Below is the whole GMakefile. I'd be very glad to hear any ideas...
Thank you,
Aleksey
-------------- GMakefile --------------------------------
LIBES = $(D_LIB) $(DISPLAYLIB) $(RASTERLIB) $(GISLIB) $(VASKLIB) $(MATHLIB)
$(DATETIMELIB) $(ZLIB)
#EXTRA_CFLAGS = -DDEBUG -DBOBMGT -DLB_LUSE_SOIL -DHUMUS -DVERELMGT -DQUAL2E
-L/usr/lib
PGM = swatgrs
LIST = \
dummy_lcra.o\
... more object files here ...
main.o
./$(PGM): $(LIST) $(LIBES)
@echo VASK = $(VASK)
@echo VASKLIB = $(VASKLIB)
@echo DATETIMELIB = $(DATETIMELIB)
@echo ZLIB = $(ZLIB)
@echo
$(LIBES): #
