[GRASS5] v.category - adding table name
I have written a simple patch for v.category. I hope it would
be useful for many GRASS users (?).
Original report:
LAYER 1:
type count min max
LAYER 2:
type count min max
Adding _table_name_:
LAYER/TABLE 1/test_obrazy_parcel:
type count min max
LAYER/TABLE 2/test_parcely:
type count min max
Martin
Martin Landa <landa@gama.fsv.cvut.cz> * http://gama.fsv.cvut.cz/~landa *
CTU Prague, Faculty of Civil Engineering, Czech Republic
(attachments)
main.c.patch (1.63 KB)
> + Fi = Vect_get_field (&In, field);
> + freps[fld]->table = G_store (Fi->table);
You must check if the connection exists, Vect_get_field can return NULL if the connection to database was not defined, then G_store (Fi->table) will crash.
Radim
Martin Landa wrote:
Original report:
LAYER 1:
type count min max
LAYER 2:
type count min max
type count min max
type count min max
Martin
*** main.c.old 2005-03-13 13:47:05.000000000 +0100
--- main.c 2005-03-13 13:56:29.000000000 +0100
*** 39,44 ****
--- 39,45 ----
    typedef struct {
      int field;
+ char *table;
      int count[FRTYPES];
      int min[FRTYPES], max[FRTYPES];
  } FREPORT;
*** 49,54 ****
--- 50,56 ----
    struct Map_info In, Out;
    static struct line_pnts *Points;
    struct line_cats *Cats;
+ struct field_info *Fi;
          int i, j, ret, option, otype, type, with_z, step;
    int n_areas, centr, new_centr;
    double x, y;
*** 326,331 ****
--- 328,335 ----
                              fld = nfreps - 1;
                              freps[fld] = (FREPORT *) calloc ( 1, sizeof (FREPORT));
                              freps[fld]->field = field;
                          freps[fld]->count[rtype]++;
*** 370,376 ****
                freps[i]->count[FR_AREA], freps[i]->min[FR_AREA], freps[i]->max[FR_AREA]);
          } else {
! fprintf (stdout, "LAYER %d:\n", freps[i]->field);
        fprintf (stdout, "type count min max\n");
        fprintf (stdout, "point %7d %10d %10d\n", freps[i]->count[FR_POINT],
--- 374,380 ----
          } else {
! fprintf (stdout, "LAYER/TABLE %d/%s:\n", freps[i]->field, freps[i]->table);
